Old Mon, Apr-16-2018, 08:06:00 PM   #331
Default Re: Best Daily Driver Suspension?
Originally Posted by Mystical View Post
Does anyone know if the Koni kit that includes both the yellow shocks and Eibach springs has the shocks pre-set for either coupe or convertible, or at last include Koni/Eibach recommendations for one vs. the other, since it is a matched set?
I've never seen confirmation and always have turned them to full soft and go from there an every set I've ever had. I doubt it's pre-set unless it's already on full soft and that's what you'd run anyway. In my experience, they've been at full soft more than not.
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Old Tue, May-15-2018, 04:24:18 PM   #332
SLOWER
SLOWER's Avatar
Reputation: 0 SLOWER is on a distinguished road
With the Eibach and Koni setup installed, I'm rubbing in the rear with 15mm spacers and 265 tires on 19" OEM wheels.
Anyone know if going to 12mm solves my problem or 10mm is best? Or do I try and add some camber back there?
Jump to top SLOWER is offline   Reply With Quote
Old Tue, May-15-2018, 04:41:32 PM   #333
A 15mm spacer is good for stock 255 tire, but I guess your 265 is just a little too much? 12 or 12.5mm should do the trick.
-NA S54-
Old Tue, May-15-2018, 06:39:13 PM   #334
oceansize
Kwisatz Haderach
oceansize's Avatar
Editing this post, I just realized i was confusing my fronts and rears. My 12.5mm spacer is on the front. I'm running 265/35/19 et22 plus a 3mm spacer in rear and am close to inner quarter panel lip. Under -2 degrees camber (wanna say -1.4), can't remember off the top of my head with 13 inch ride height for both front and rear.
Wrong info is below this:
I'm running 265/35/19 in the rear and have 12.5mm spacers but with KW v2. 13 inch ride height front and rear. I don't rub but I'm very, very, very close.
Where exactly are you rubbing at? I'm assuming your rubbing on the top inner quarter panel lip, that is where I'm so close. A 12.5 "should" be ok but it is tight, very tight.
2003 M3 Convertible SMG w/Hardtop
KW V2 Coilovers
ESS VT1-475 Gen 3 Supercharger
Stoptech Brakes
MRR GT-1 Wheels
TTFS SMG Tune
Rogue Eng. Diablo Exhaust w/ SS Tips
Rogue Eng. Rasp Pipe
Redish Reinforcement Plates
Polyurethane Rear Subframe Bushings
Polyurethane Differential Bushings
Beisan Oil Pump Disk
Last edited by oceansize; Tue, May-15-2018 at 07:20:03 PM. Reason: Hit the post button too quick.
Old Tue, May-15-2018, 09:07:46 PM   #335
SLOWER
SLOWER's Avatar
I was mixing up cars. M3 has 255 rears and a 15mm spacer and rubs.
I will hunt down or trade for some 12mm.
Old Wed, May-16-2018, 03:05:43 PM   #336
mercedesc63
Reputation: 0 mercedesc63 is on a distinguished road
I am running oem 18” square on brand new oem spec bilstien b4 with stock springs. 255/35/18 all around with a 20mm spacer out back and i experience no rubbing whatsoever.
I’d imagine that if my car was on a set of conservative lowerig springs like eibach it wouldnt rub and if it did it wouldnt be bad at all.
Jump to top mercedesc63 is offline   Reply With Quote
Old Wed, May-16-2018, 03:50:55 PM   #337
icecream
Registered Apples
icecream's Avatar
Quick update on the B4 setup. I have always been under the impression that ot was slightly under damped with the eibachs. Had a buddy that runs konis on his M3 ride with me and he immediatly mentioned it felt quite underdamped. I only jad my work out suspension to compare to so it felt better to me. Either way, not bad but after dricing for over a year and a half on them and the eibachs, I would definitly go woth konis or the hd shocks. I suspect o stick springs they woyld work quite a bit better.
Old Wed, May-16-2018, 08:58:38 PM   #338
SunD3v1L
hi
SunD3v1L's Avatar
Reputation: 0 SunD3v1L is on a distinguished road
Italy
I've had Eibachs for the last 5 years and I've never rubbed.
OEM ZCPs with OEM sizes, though. And no spacers.
Jump to top SunD3v1L is online now   Reply With Quote
Old Wed, May-16-2018, 09:03:08 PM   #339
Ride height should never be considered a factor in rubbing.
Old Wed, May-16-2018, 09:28:20 PM   #340
HassanEido
HassanEido's Avatar
Lebanon
it's funny that a friend of mine has hds and says the same thing about them.
I would go with konis, period.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Discussing Best Daily Driver Suspension? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
