Old Mon, Jul-04-2016, 01:59:50 PM   #1
pawa_k2001
Track Junkie
pawa_k2001's Avatar
Reputation: 0 pawa_k2001 is on a distinguished road
Ukraine
Default Wiring in SMG to Manual Clutch switch factory style
I am working with a donor car to swap my 2002 M3 from SMG to manual. My goal is to wire everything in by just plugging in all the wires into the correct connects. So everything looks just like it come from factory.
My only problem is that the donor is year 2004 build. I see that everyone has a light blue wire where I have a grey wire. Can anyone check if the factory wire on the clutch switch was grey?
Suspension: AST 4100 GTS Suspension, Vorshlag camber plates, Mason front strut bar
Engine: Evolve R Software, Status Gruppe SCZA exhaust
Exterior: Status Gruppe front valance
Brakes: Bimmerworld brake stiffener kit
Wheels: Apex ARC-8 18x9.5" W/ Dunlop Star Spec tires 275/35/18
Jump to top pawa_k2001 is online now   Reply With Quote
Old Mon, Jul-04-2016, 03:09:27 PM   #2
Pnick
Pnick's Avatar
Default Re: Wiring in SMG to Manual Clutch switch factory style
Clutch switch are separated by years "up to 2001_03" and "as of 2001_03". From the looks of it, both have gray wire coming out of the clutch switch (pin 2 on connector X11143 or X13635 depending on the year) going to pin 7 of connector X6011 which eventually goes to the gear recognition switch.
Old Mon, Jul-04-2016, 04:02:01 PM   #3
pawa_k2001
Track Junkie
pawa_k2001's Avatar
Ukraine
Thanks. Looks like this will work. My M3 is 2001_07 build, I am guessing the very early models had some difference. I will be getting the correct transmission wiring (p/n 12517831756) which will have the gear switch recognition plug and wiring.
The grey wire will be pinned to pin 7 on a connecter in the engine bay. I checked, SMG models have an empty spot in that pin number. Manual models(my donor car) has the grey wire from clutch switch pinned into it.
If everything goes well, I will make a DIY thread for people that want to do the same thing. Bit of a pain to snake all the wires correctly but I hope it will be worth it.
Old Mon, Jul-04-2016, 05:21:00 PM   #4
SeattleLSB
SeattleLSB's Avatar
Reputation: 0 SeattleLSB is on a distinguished road
You could just buy the transmission harness for $230
2011 AW/BLK E90 M3>DCT
2003 LSB/BLK M3>SMG
2003 AW/BLK 330XI>AT>Winter Beater
Jump to top SeattleLSB is offline   Reply With Quote
Old Mon, Jul-04-2016, 05:44:41 PM   #5
pawa_k2001
Track Junkie
pawa_k2001's Avatar
Ukraine
I will be buying it. You still need to wire in the clutch switch. Clutch switch is not on the transmission wiring.
Old Wed, Jul-06-2016, 12:37:39 PM   #6
pawa_k2001
Track Junkie
pawa_k2001's Avatar
Ukraine
Took 3 hours but I wired everything in factory style, pulled all the wires through the loom as they should go and pinned them in.
Manual transmission wiring should be installed Friday and I have an appointment to reprogram all the modules on Thursday, July 14th. I will update the thread with the results.
Old Wed, Jul-06-2016, 02:57:42 PM   #7
SeattleLSB
SeattleLSB's Avatar
Looks great, good work!
2003 LSB/BLK M3>SMG
Old Mon, Mar-27-2017, 10:08:44 PM   #8
TheCoder
TheCoder's Avatar
Reputation: 0 TheCoder is on a distinguished road
Hey Sorry for reviving an old post, but did you end up soldering Pin 2 of the clutch switch to the grey wire leading to PIN 7 of the X6011 plug? (the grey wire)?
2002 Titanium Silver BMW 325Ci SOLD
2003 Estoril Blue BMW M3
2003 Estoril Blue BMW M3 Journal
How to Import a car from Canada
Jump to top TheCoder is offline   Reply With Quote
Old Tue, Mar-28-2017, 01:34:59 AM   #9
TheCoder
TheCoder's Avatar
Old Tue, Mar-28-2017, 01:08:48 PM   #10
pawa_k2001
Track Junkie
pawa_k2001's Avatar
Ukraine
I didn't, it just plugged into the rear of the plug.
Discussing Wiring in SMG to Manual Clutch switch factory style in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
