Old Mon, Jul-03-2017, 05:21:06 AM   #491
bigjae1976
Default Re: Rod Bearings
Originally Posted by divedoc View Post
Huh, very interesting. I suppose it makes no real difference in the end...just one of those little historical bits of trivia that would be nice to track down.
If I had to guess...037/038 were pre-recall bearings. Some MY 2003 cars had the bearing recall done. I'm sure some were missed.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Mon, Jul-03-2017, 05:37:28 AM   #492
divedoc
Reputation: 0 divedoc is on a distinguished road
That's my guess as well. Mine is a 2003.5 and has the newer rod bolts, and wasn't part of the recall, but it certainly could have used an older bearing specification.
2003 Jet Black/Gray M3 Coupe 6MT
Jump to top divedoc is offline   Reply With Quote
Old Fri, Dec-01-2017, 07:39:45 PM   #493
M3gtr2b
M3gtr2b's Avatar
Reputation: 0 M3gtr2b is on a distinguished road
Originally Posted by Good View Post
Love looking at these DIYs, just so I know it's worth paying $800 for the fix.
Who did your rod bearing for $800,my car is due for the job?
Jump to top M3gtr2b is offline   Reply With Quote
Old Fri, Dec-01-2017, 07:40:21 PM   #494
Good
@GOOD_M3
Good's Avatar
Are you located in LA?
2006 M3 SILBERGRAU COMPETITION
EXTERIORJCSL 1X1 DIFFUSER | V÷RSTEINER CSL BUMPER
PREVENTATIVE ▌ VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | RESONATED X-PIPE SEC 2 | SPORT (GEN 2) SEC 3
BRAKES ▌ STOCK CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌ STOCK ZCP BBS 19" | 75MM ECS/TMS F&R WHEEL STUD CONVERSION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V2 COILOVERS | GROUND CONTROL CAMBER PLATES | SDW RTABS
ENGINE ▌ TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OEM SNORKEL (FLAP DELETE), OIL CATCH CAN
TRANSMISSION ▌'255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Old Fri, Dec-01-2017, 07:57:00 PM   #495
M3gtr2b
M3gtr2b's Avatar
Canoga park.
Old Sun, Mar-11-2018, 05:01:02 AM   #496
trumpsterfire
Reputation: 0 trumpsterfire is on a distinguished road
Great DIY, thanks for all the info!
Jump to top trumpsterfire is online now   Reply With Quote
Old Mon, Apr-16-2018, 05:18:16 PM   #497
den_bart
den_bart's Avatar
Reputation: 0 den_bart is on a distinguished road
Originally Posted by SYT_Shadow View Post
I'm suffering severe withdrawal now that I no longer have a garage... it sucks!
I still remember my first valve adjustment in the middle of NY winter out in the open... dressed in full ski clothes and I still froze
It isn't that bad. Complexity wise it's easier than vanos work.
I'm confident now after this... I did the vanos overhaul before and that took forever
Jump to top den_bart is offline   Reply With Quote
Old Sat, Dec-15-2018, 09:52:13 PM   #498
M3AZ
///M3AZ
Reputation: 0 M3AZ has disabled reputation
At what point does one throw out a bolt because the tightening procedure went astray? I’ve had a couple where the socket slipped off halfway through the angle torque. Can I just back it off and start the procedure again with the same bolt or do I need to use a new bolt?
Jump to top M3AZ is online now   Reply With Quote
Old Sat, Dec-15-2018, 09:53:24 PM   #499
NotUrAvgM
Reputation: 0 NotUrAvgM is on a distinguished road
Originally Posted by M3AZ View Post
At what point does one throw out a bolt because the tightening procedure went astray? Iíve had a couple where the socket slipped off halfway through the angle torque. Can I just back it off and start the procedure again with the same bolt or do I need to use a new bolt?
I did the same thing a couple times. Pitch it.
-Matt
[2004 330xi/6] Orient/Natural :: 147k :: ZSP :: ZPP :: ZCW
[1998 M3/4/5] Cosmos/Black :: 126k ::TCKline D/A (500/600) :: GC plates :: RD Sways :: GC Rear Arms :: BW FCAB :: BW RTAB :: AKG Subframe :: 3.64 Diffsonline :: TMS Pulleys :: AA + Borla :: XBrace :: AS SSK :: ZHP Rack :: M50 :: DTC60 :: Direzza ZIII :: Safety Equipment
[2016 Yamaha R3] White/Red
Past:
[1995 M3] Avus/Dove :: 242k :: S52 OBDI :: M50 manifold :: 3.5" HFM :: Turner Chip :: XBrace :: SS Lines :: Turner RTABS :: Vogtland CS :: Bilstein Sport
[1999 M3] Cosmos/Black :: 87k :: TCKline S/A (400/500) :: Turner plates :: UUC Front Sway :: PF RTABs :: AA Intake :: Borla :: XBrace :: TRM C2s :: CL RC6E :: Direzza ZII :: Safety Equipment
[1993 325is] Brilliant/Black :: 139k :: Bilstein sports :: Eibach sways and springs :: Dinan camber plates and chip :: Borla :: LSD
[1983 320i] Safari/Brownish :: 242k :: homebrew CAI :: some rust :: multicolor body panels
Jump to top NotUrAvgM is offline   Reply With Quote
Old Sat, Dec-15-2018, 10:17:20 PM   #500
M3AZ
///M3AZ
At this rate I should have ordered 100 bolts.
I assume that means if Iím on the third round tightening, Iíd have to throw out both bolts if I screw up either of them. The SB doesnít say whether both bolts have to be torqued together or whether one can be torqued first then the other. I assume they should be done together.
Discussing Rod Bearings in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
