Old Mon, Mar-12-2018, 05:17:11 AM   #31
mrgizmo04
mrgizmo04's Avatar
Default Re: M3 E46 Pre Cat O2 sensor replacement...
I am not 100% sure what is going on in the last ~10 posts, but here are sensors I got (they are Bosch) on Amazon for a fraction of the cost.
Did not need to splice anything or change any connectors/plug.
Bosch 13949 Oxygen Sensor, OE Type Fitment (UPSTREAM - FOR CYLINDERS 1-3)
Bosch 13952 Oxygen Sensor, OE Type Fitment (UPSTREAM - FOR CYLINDERS 4-6)
Bosch 15138 Oxygen Sensor, OE Type Fitment (DOWNSTREAM - FOR CYLINDERS 1-3)
Bosch 13951 Oxygen Sensor, OE Type Fitment (DOWNSTREAM - FOR CYLINDERS 4-6)
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, Mar-12-2018, 05:28:18 AM   #32
M3_Pilot
+1
Well. The parts. I bought mine from pepboys during an internet sale for a steal.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Mon, Mar-12-2018, 05:37:55 AM   #33
M3_Pilot
BTB, why are you removing things? I just changed my pre cat o2s with a crow's foot and the only thing I did besides jacking the car up was removing the valve beauty cover to expose the harnesses for the O2s.
Yes, but don't you have euro headers? The sensors are placed further down the pipes as opposed to the us headers.
Originally Posted by delvin View Post
So just to clarify they are the same sensor with a different plug? I just got a SES for pre cat O2's tonight and I have no problem wire splicing.
Yeah, pretty sure that's the case. Funny, my SES light came on as well for my bank 1 pre cat so I ended up replacing it.
@jet.m3
Old Mon, Mar-12-2018, 05:50:46 AM   #34
Ya you're right, I wasn't even thinking of stock headers.
As far as the sensors go, you cn but the OE/OEm part or you can buy a generic bosch and splice your old plug into the new sensor and save some $.
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Mon, Mar-12-2018, 11:50:45 AM   #35
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
Prices on these Bosch sensors are absolutely absurd, you are basically paying a massive tax get them with the BMW connector. Bosch is the OEM for tons of O2 sensors for other companies and can be had much cheaper, but you'd likely need to do some repinning. I probably wouldn't pay more than $30 for a narrowband switching O2 sensor personally. Luckily I haven't had to deal with this issue, but when the time comes you can bet I won't be buying a $100 sensor. You can get Bosch LSU 4.9 widebands for around $30 if you know what to look for, so there is no reason a narrowband with much older technology should cost $100.
Jump to top ctres is offline   Reply With Quote
Old Mon, Mar-12-2018, 01:56:40 PM   #36
delvin
Water Champion
Reputation: 0 delvin is on a distinguished road
Thanks guys
Jump to top delvin is offline   Reply With Quote
Old Tue, Mar-13-2018, 10:35:31 PM   #37
Alex Sol
Alex Sol's Avatar
Reputation: 0 Alex Sol is on a distinguished road
@ctres i looked up the 4.9 wideband but couldn't find any for $30.. where would you find these?
1991 Guards Red Porsche 964 C2
2009 335d
2003 m3
Jump to top Alex Sol is offline   Reply With Quote
Old Tue, Mar-13-2018, 10:50:41 PM   #38
ctres
ctres's Avatar
Motorcraft DY1303, DY1311, among others, but those ones I can confirm. I still need to check the pinout and connector against the typical aftermarket Bosch LSU4.9, but the sensors are legit Bosch.
Bosch and NTK are probably the two biggest suppliers of wideband UEGO sensors to the auto industry, and most new vehicles these days have factory widebands so they are getting very cheap. I'm sure there are other OEMs using the same Bosch sensors, but I haven't searched around much.
Old Mon, Apr-16-2018, 09:09:07 PM   #39
delvin
Water Champion
Bought two of the 15703's for $25 each and installed this weekend after soldering the wires together. I've done 45 miles without any codes, mixed driving and a lot of idling. I got the code both times after idling in a line for 3-5 minutes.
If I was to do it again I would buy the 4 place weather pack connectors and hook them up that way instead of solder. I'd like to actually get someones defective O2's and redo it with the connector so in the future it would be plug and play without removing the beauty cover.
Update:Made a 400 mile round trip down to Austin, no codes. Works great 10/10 would recommend
Old Tue, Jun-26-2018, 08:58:09 PM   #40
dutchhome
Reputation: 0 dutchhome is on a distinguished road
Since I'm looking these part numbers up right now anyway I thought I would update this thread. Here are the official Bosch part numbers for E46 M3's along with the current prices on Amazon. These will have the correct wire length and connectors.
2001-2006 M3:
Bosch 13949 (pre-cat 1-3) $89.64
Bosch 13952 (pre-cat 4-6) $63.78
Bosch 15138 (post-cat 1-3) $80.78
Bosch 13951 (post-cat 4-6) $101.78
I was able to get 3 of these in Like New / Packaging Damaged condition for significantly less ($204.14 instead of $335.98). Hopefully they really are like new and people didn't just buy them and return the boxes with different parts.
Edit: I didn't realize these are the same part numbers that were listed a few posts above. I wasn't sure where any of these part numbers came from so I looked them up myself on Bosch's web site.
Jump to top dutchhome is offline   Reply With Quote
Discussing M3 E46 Pre Cat O2 sensor replacement... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
