E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#21 |
Constantly Learning M3 and M5 Owner
![]() Location: Northern Virginia
Good point. I have an aftermarket Agency Power section 1, Supersprint 2 and Agency Power 3, but no aftermarket headers.
Shouldn't affect this DIY, correct? ![]()
BLUE HEAVEN: Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here |
Sponsored Links |
#22 |
CPV O-Ring Guy
![]() Location: Maryland
That's right, it will not affect the install. I know a lot of people keep saying to access from the top, but I'm thinking you will have better access from the bottom, with the reinforcement plate removed but it is the most difficult sensor to access for sure.
///M3 - Dream Car: Acquired 15-Year Member 2003 M3Laguna Seca Blue/6MT/Black Leather Cloth Interior/Full [CSL] Exhaust/evolve-R Original Owner, Custom Built - PDC, Moonroof, Bi-xenons (TFX), Brushed Aluminum Trim, Bluetooth ULF European - Rotors (F&R), Bumper, Mirrors, Warning Triangle, Console, LSZ, First Aid Kit, Fire Extinguisher OE LED Conversion/Outer Ring Mod | V1 Hardwired/Ashtray Display | 3M 35% Tint | Intravee II, Diamond H600s, JL 10W3v3, HD900/5 |
#23 |
![]() Location: Chicagoland
Bumping up this thread... Doing both my precat O2 sensors, I removed the egr valve and have the heat shield above the headers loose, but I can't get it out. It seems impossible without disconnecting this coolant line:
![]() Can anyone tell me how they got their heat shield off? And if I have to disconnect the coolant line, is all of my coolant in the reservoir going to drain out?? That would be a pita Edit: After taking off the lower skid plate I realized that with my sgt headers all four oxygen sensors are pretty easily accessible under the car. Looks like I didn't need to loosen the heat shield in the first place! ![]()
UIUC / TU Munich Mechanical Engineering 2018 2003 ///M3 6MT Coupe Imola Red/Black Napa, slicktop, manual seats My Journal Last edited by BTB; Wed, Dec-30-2015 at 07:10:47 PM. |
#24 |
#25 |
#26 |
#27 |
BTB, why are you removing things? I just changed my pre cat o2s with a crow's foot and the only thing I did besides jacking the car up was removing the valve beauty cover to expose the harnesses for the O2s.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav______________________JOURNAL ![]() -Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · AP Headers · Euro cat sect 1 · Dinan sect 3 · BMW Motorsport 4.10 · Besian · D/A pullies/fan delete · WPC rod bearings -TMS Camber & Subf plates · RE Street Trans Mounts · AKG poly SUB/DIFF · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs -OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · ss brake/clutch lines -Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10" |
#28 |
Why? It's perfectly fine if you have decent wire splicing skills.
#29 | |
![]() Location: München
![]() Quote:
![]() Sent from my Redmi Note 4 using Tapatalk
![]() #E36S54 #CSLWannabe #TTFS @Mykesf
#30 | |
Water Champion
![]() Location: FT. Worth
![]() Quote:
Bookmarks |
Thread Tools | |
Display Modes | |
