Old Sat, Jan-21-2017, 03:09:27 AM   #41
drrwise
Reputation: 0 drrwise is on a distinguished road
Default Re: Car stalls ransomly when coming to a light...
I went through stalling for over a year - no codes. Adaptions fixed it temporarily, until the car adapted back to 14.7:1.
ICV/O2 sensors/plugs/coils/vacuum tested/fuel pump/filter/injectors etc.
Turned out to be the crank position sensor.
http://www.m3forum.net/m3forum/showp...&postcount=141
03 6mt, topaz, daily driver, 235k
4.10s, 30% AS SSK, Mason Clutch, JL Audio amp/sub, Beisan Vanos, Euro console/aux, VMR 718s, TTFS NA tune
Specialty Tools Available
Cox Epoxy Guns (200mL/400mL), Shim kit, Cam timing tool
Jump to top drrwise is offline   Reply With Quote
Old Sat, Jan-21-2017, 08:25:48 AM   #42
E46_USMC
E46_USMC's Avatar
Reputation: 0 E46_USMC is on a distinguished road
I had this problem when I had a KN intake. I replaced the fuel pump and fuel filter at the same time I got a tune from TTFS and it went away, so the answer for me lies somewhere in there.
But if it turns out to be your crank position sensor, I have a brand new one for ya that I got when I was having these problems, just never got around to installing it. Didn't even open the thing.
Jump to top E46_USMC is offline   Reply With Quote
Old Sun, Jan-22-2017, 05:52:30 PM   #43
mikentosh
Reputation: 0 mikentosh is on a distinguished road
Here's another long shot possibility, but easy to check. I was having same symptoms and we found the previous owner had put in an aftermarket clutch pedal stop and taped away the pedal position sensor as he couldn't figure out how to properly shim it. With it back in place and correctly adjusted its driving great again.
Jump to top mikentosh is offline   Reply With Quote
Old Mon, Jan-30-2017, 02:43:35 PM   #44
zippity
Reputation: 0 zippity is on a distinguished road
My car was converted from smg to manual. So this may have something to do with it. I will check it out.
Jump to top zippity is offline   Reply With Quote
Old Mon, Jan-30-2017, 02:47:52 PM   #45
zippity
I may hit you up for this, but it looks like most people are throwing codes when this sensor becomes faulty. As of now, I have zero codes. I just put in a new alternator as well. Add that to the list of new items.
Old Tue, Jan-31-2017, 03:53:20 AM   #46
irdave
Reputation: 0 irdave is on a distinguished road
I'm having a bit the same issue, and have been thinking about just turning up the idle a little bit... Did that when I had the 325 in the car and it solved a lot of little issues...
Jump to top irdave is offline   Reply With Quote
Old Tue, Jan-31-2017, 06:01:23 PM   #47
zippity
I want to find the source of the problem rather than band aid it.
Old Wed, Feb-01-2017, 02:09:41 AM   #48
drrwise
Check out my post. I had zero codes for over a year when my crank sensor went. Random stalling that got worse every day. I only replaced the sensor after running out of things to try.
Frustrating, I wasted a bit of cash and time because no codes and bad advice. The only things left to replace are ping and intake cam sensors.
Cant complain too much, I've got 215k on the original motor and clutch.
Sent from my GT-P3113 using Tapatalk
Old Wed, Feb-01-2017, 02:10:06 PM   #49
zippity
Can you post a link to your thread?
Old Wed, Feb-01-2017, 03:28:43 PM   #50
kyrix1st
kyrix1st's Avatar
Japan
Oil separator is a major suspect; was the case for my engine.
It could also stall due to a bad fuel pump relay (mine was burnt out)
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
car, coming, light, ransomly, stalls
Discussing Car stalls ransomly when coming to a light... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
