Old Sat, Aug-31-2013, 04:54:31 PM   #31
harut44
Reputation: 0 harut44 is on a distinguished road
Default Re: Car stalls ransomly when coming to a light...
Originally Posted by Yoshie View Post
use the on dash computer to monitor the voltage. You can get real time while you drive. I don't think this is your issue, but it's a real easy test.
It reads at an average of 14.1v while on idle. From what I read, this is the norm.
Jump to top harut44 is offline   Reply With Quote
Old Sun, Sep-29-2013, 03:23:40 PM   #32
harut44
Changed my battery. Solved all idle issues.
Old Thu, Jan-19-2017, 10:53:31 PM   #33
zippity
Reputation: 0 zippity is on a distinguished road
Bringing this thread back from the dead. I am suffering from this exact issue. However, I have installed a new battery, new maf, new air filter, idler pulley, belts and cleaned the ICV...What's next? Fuel filter? Fuel pump? New ICV?
Jump to top zippity is offline   Reply With Quote
Old Fri, Jan-20-2017, 01:49:39 PM   #34
bimmerfan08
bimmerfan08's Avatar
Originally Posted by deilenberger View Post
BTW - what's "ransomly"?
Originally Posted by Noodle555 View Post
How much ransom do you have to pay to get going?
Originally Posted by Gary Powers View Post
had me bawling
Originally Posted by WRX2BIMA View Post
hahaha i was thinking the same thing.. "edit before posting brahh"
Old Fri, Jan-20-2017, 01:50:19 PM   #35
bimmerfan08
Any codes?
Old Fri, Jan-20-2017, 01:51:48 PM   #36
zippity
Originally Posted by bimmerfan08 View Post
Any codes?
It was shooting a MAF code, but one I put in the new MAF, that went away and no new codes since.
Old Fri, Jan-20-2017, 06:48:50 PM   #37
babydocjd
babydocjd's Avatar
Reputation: 0 babydocjd is on a distinguished road
stock intake or aftermarket? also, I would suggest having your adaptations reset after installing the new MAF. This was the solution to my stalling problem at lights.
///M Life
Jump to top babydocjd is offline   Reply With Quote
Old Fri, Jan-20-2017, 06:53:29 PM   #38
zippity
Stock intake and stock filter. What do you mean reset adaptations? How can I go about this? Is this the throttle down and key in position 2?
Old Fri, Jan-20-2017, 07:01:40 PM   #39
babydocjd
babydocjd's Avatar
Stock intake and stock filter. What do you mean reset adaptations? How can I go about this? Thanks.
you have to have access to GT1, INPA/EDIBAS or know someone that does. Or take it to your indy shop and tell them to reset your car's adaptations. From my minimal understanding it has something to do with your DME and fuel trim/air intake readings. did a quick search and found this. http://images.activeautowerke.com/pd...20E46%20M3.pdf
///M Life
Old Fri, Jan-20-2017, 07:35:09 PM   #40
zippity
Damn. Didn't want to bring it any where. I was hoping to figure this one out on my own.
car, coming, light, ransomly, stalls
Discussing Car stalls ransomly when coming to a light... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
