Old Thu, Mar-12-2009, 02:46:33 AM   #21
not4kt
Reputation: 0 not4kt is on a distinguished road
Good info, I have been looking for information on this topic. I knew there was a reason I joined this group.
Jump to top not4kt is offline   Reply With Quote
Old Thu, Mar-12-2009, 02:15:15 PM   #22
el8
Reputation: 0 el8 is on a distinguished road
Originally Posted by Cazz View Post
It took me an afternoon. If you have experience taking the steering wheel cover off and getting to the LCM you should be able to do it faster. I could probably do the same job in about an hour the second time. The slowest parts are finding the correct wires to tap into on the LCM, finding the correct pin on DME and figuring how where to feed the wire through the firewall. Also, I accidentally popped the slip ring off and spent some quality time putting the clock spring back in. The DIY I was using said to remove the steering wheel. I don't think that is needed. The steering wheel covers and the column cover should come out without removing the 16mm bolt.
If I can find my USB camera cable I'll try to post some pics.
You probably need to hook up all 3 wires: DME, power, i-bus.
Yeah. The whole ZCP panel confuses me. It has almost all the circuitry of the right side of the multifunction panel, yet only acts as a momentary switch. It uses no power or i-bus and I have tested that the only thing it does is connect 2 wires when the track button is pushed. Sad.
Since all 4 wires to the multifunction are being used, BMW could not add track mode to the wheel without changing the connector, the slip ring, etc. Still, they should have been able to add it to the dash, the column, or somewhere else.
Next tell me you're in the DC area and willing to do installs
Jump to top el8 is offline   Reply With Quote
Old Fri, Mar-13-2009, 01:27:39 AM   #23
Cazz
High plains drifter
Cazz's Avatar
Reputation: 0 Cazz is on a distinguished road
Only if DC = Denver Colorado and I get to keep any loose change I find.
2005 ZCP M3 + Multifunction controls
Jump to top Cazz is offline   Reply With Quote
Old Fri, Mar-13-2009, 02:23:22 PM   #24
el8
Where would the best place be to buy the MFL panel? Can't find the part on Tisher.
*edit* looks like this is it.
Old Thu, Mar-19-2009, 01:41:54 PM   #25
M3prof
M3prof's Avatar
Reputation: 0 M3prof is on a distinguished road
Originally Posted by tom @ eas View Post
On the BT activation button, why not use the pairing button leads in the center console? It's simply a matter of shunting 2 leads with a momentary button.
Tom:
By bluetooth activation, do you mean the talking man button on the steering wheel that activates voice commands? You think connecting a momentary button to the wires in the arm rest console will activate voice control? The OEM steering wheel talking man button has different responses depending on how long it is held down (i.e. a short press vs a long press). Would this still behave correctly?
2005 M3 Silbergrau Metallic on black; 6MT, ZCP, ZPP, ZCW, Nav, Dinan exhaust, two AR20 resonators in section 1, Autosolutions SSK, Turner rear adjustable camber arms, Fucy CSL diffuser, Intravee II, stealth V1 install with ash tray remote, OEM first aid boxes under both seats, Ultimate pedals and more...
Jump to top M3prof is offline   Reply With Quote
Old Thu, Mar-19-2009, 01:45:10 PM   #26
M3prof
M3prof's Avatar
Post pics, that would be great. I am not clear what the LCM module has to do with this retrofit...
Old Thu, Mar-19-2009, 08:19:59 PM   #27
tom @ eas
tom @ eas's Avatar
Reputation: 0 tom @ eas is on a distinguished road
Originally Posted by M3prof View Post
Tom:
No, I'm referring to the console button on ULF systems, this is an 18-pin connector. I'm not 100% how this would behave with TCU-specific systems but would assume it should be fine since the steering wheel buttons are non-specific.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG FACEBOOK YOUTUBE FLICKR INSTAGRAM
Jump to top tom @ eas is offline   Reply With Quote
Old Sun, Mar-22-2009, 01:10:02 PM   #28
M3prof
M3prof's Avatar
It was my understanding that the BMW ULF pairing button that is typically mounted in the center arm rest console is no longer available and that a momentary interrupt switch can be used instead. What I don't understand is that the similar talking man button on the steering wheel is interpreted as two different iBus commands depending on whether it is a short press (interpreted as redial) or a long press (interpreted as activate voice control). I was wondering whether a momentary interrupt switch installed in the center console armrest (just like the ULF pairing button) would work like the talking man steering wheel button for TCU systems. Seems to me that the talking man button on the steering wheel has to be more than a simple momentary interrupt button and has to send specific iBus commands when pressed.
Old Sun, Mar-22-2009, 06:32:06 PM   #29
tom @ eas
tom @ eas's Avatar
The button is only a momentary switch with backlight - no specific device signature is present.
Old Thu, Apr-16-2009, 11:04:36 PM   #30
RedM3/4
Default Cazz, can you confirm retrofit parts/numbers in doc?
Looks like I'll soon be the owner of a 2006 ZCP, flying out and driving home 1100 miles, so I'd like to do this for the drive home.
I went to the dealer asking about the retrofit part numbers in the PDF, but there's not much description. It appears from cost and weights shown that:
65 71 0 021 159 is the kit one needs for a ZCP, but they don't list the parts you get. This p/n weighs about .2 lb per local dealer. No way to know if it is the upper cover with buttons plus the harness, but hopefully so.
Likewise,
65 71 0 026 223 I'm guessing is the whole steering wheel based on the $500 + price, but again no parts listed. Forget the weight but think it was 2 lbs.
Maybe you ordered the top cover/buttons only and made your wires? but the link isn't current. Even so, can you provide that part number and approximate cost? I'll look it up on realoem I guess, but I'm willing to buy the kit in these remote/short timeframe circumstances if I can verify that's what I need. I can do the M-mode button relocation after I get home. The point here, question I'm trying to clarify is these parts listed in the PDF appear to be that you need one or the other, not both, correct?
Thanks for any answers.
ADS
Soon to be owner of 2006 ZCP, Imola/black. Buying from the little old lady from Pasade... oops, Norwalk, CT! Actually, she's close to my age, but sounds cool!
buttons, car, info, radio or telephone, steering, wheel, zcp
Replaced ZCP steering wheel with OEM Leather Multi Function. BUTTONS NO WORK!Help? thesilverm3guy E46 M3 (2001-2006) 11 Fri, Oct-17-2008 11:51:50 AM
Changing TWO Buttons on my steering wheel. R/T and the other one. Is it possible? jamesbond E46 M3 (2001-2006) 10 Tue, Aug-22-2006 09:37:21 AM
Unused steering wheel buttons Eastwwood E46 M3 (2001-2006) 1 Thu, Feb-16-2006 06:51:38 AM
Steering wheel buttons what are these for? brownie E46 M3 (2001-2006) 4 Wed, Oct-26-2005 02:37:59 AM
Looking for a Satellite Radio receiver that I can contro using the wheel buttons lozarus Audio/In Car Entertainment (I.C.E.) 5 Wed, Jun-01-2005 01:33:39 PM
Discussing Info on steering wheel radio/telephone buttons on a ZCP car in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
