Old Tue, Mar-10-2009, 09:55:41 PM   #11
RedM3/4
Default MFL on ZCP threads
I've read these until I'm circling back on threads. Nice it works and there's even a kit, etc, but just to be clear, does cruise control work or just left side? I'm guessing so since you moved the M button, just want to verify.
Th
ADS
Last edited by RedM3/4; Tue, Mar-10-2009 at 09:57:41 PM. Reason: typo in subject line
Old Tue, Mar-10-2009, 11:09:27 PM   #12
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
if i read this correctly, everything should work except for cruise control as it uses the same pins as zcp DSC.
Tischer aka GetBmwParts
Old Wed, Mar-11-2009, 06:05:35 AM   #13
Cazz
High plains drifter
Cazz's Avatar
Reputation: 0 Cazz is on a distinguished road
Yes. I have cruise working using the right side buttons (plus the radio buttons work on the left side). I can engage/disengage track mode using my added button.
Cruise control is built into the DME and you just have to add the wiring and buttons to be able to send the commands for it to work. No special dealer activation is required.
2005 ZCP M3 + Multifunction controls
Jump to top Cazz is offline   Reply With Quote
Old Wed, Mar-11-2009, 06:33:25 AM   #14
daytonaviolet
OEM CSL Whoore
great info man!! if i had a zcp i'd be all over this mod
Old Wed, Mar-11-2009, 02:42:26 PM   #15
cntrvrsy
44
cntrvrsy's Avatar
United Nations
That's pretty sick! Too bad we can't easily adapt M Track mode to non ZCPs, especially pre-CSL e46 M3s (no icon in the dash). I did some digging on RealOem and the DSC module is different, that and a few other things. Can't remember exactly cause I never saved what I found .
sig engineered by Fcukupayme
Jump to top cntrvrsy is offline   Reply With Quote
Old Wed, Mar-11-2009, 08:02:27 PM   #16
el8
Reputation: 0 el8 is on a distinguished road
Cazz, how long did the mod take? Enabling cruise was just a matter of rewiring pin 8 on the harness to the DME?
Jump to top el8 is offline   Reply With Quote
Old Wed, Mar-11-2009, 09:03:07 PM   #17
RedM3/4
Default Thanks Cazz, most awesome!
I've started looking for E46M3s now that my son is almost out of college. Now I can go ZCP if the rest of the car is what I want and plan my first mod before I even buy the car, whoohoo!
ADS
Old Wed, Mar-11-2009, 10:24:28 PM   #18
M3prof
M3prof's Avatar
Reputation: 0 M3prof is on a distinguished road
This is really interesting, I have a ZCP car and a older steering wheel panel in the basement with both the radio buttons and cruise control buttons...now to find the time to wire it up!
Seems like BMW was getting away on the cheap by reusing the CSL steering wheel panel to activate M-track mode rather than creating a new button panel with an extra button somewhere else. Hence ZCP cars lost access to the cruise and radio control, even though it's present. Now we know how to get it back!
2005 M3 Silbergrau Metallic on black; 6MT, ZCP, ZPP, ZCW, Nav, Dinan exhaust, two AR20 resonators in section 1, Autosolutions SSK, Turner rear adjustable camber arms, Fucy CSL diffuser, Intravee II, stealth V1 install with ash tray remote, OEM first aid boxes under both seats, Ultimate pedals and more...
Jump to top M3prof is offline   Reply With Quote
Old Thu, Mar-12-2009, 03:28:54 AM   #19
Cazz
High plains drifter
Cazz's Avatar
It took me an afternoon. If you have experience taking the steering wheel cover off and getting to the LCM you should be able to do it faster. I could probably do the same job in about an hour the second time. The slowest parts are finding the correct wires to tap into on the LCM, finding the correct pin on DME and figuring how where to feed the wire through the firewall. Also, I accidentally popped the slip ring off and spent some quality time putting the clock spring back in. The DIY I was using said to remove the steering wheel. I don't think that is needed. The steering wheel covers and the column cover should come out without removing the 16mm bolt.
If I can find my USB camera cable I'll try to post some pics.
You probably need to hook up all 3 wires: DME, power, i-bus.
Yeah. The whole ZCP panel confuses me. It has almost all the circuitry of the right side of the multifunction panel, yet only acts as a momentary switch. It uses no power or i-bus and I have tested that the only thing it does is connect 2 wires when the track button is pushed. Sad.
Since all 4 wires to the multifunction are being used, BMW could not add track mode to the wheel without changing the connector, the slip ring, etc. Still, they should have been able to add it to the dash, the column, or somewhere else.
Old Thu, Mar-12-2009, 03:43:32 AM   #20
tom @ eas
tom @ eas's Avatar
Reputation: 0 tom @ eas is on a distinguished road
On the BT activation button, why not use the pairing button leads in the center console? It's simply a matter of shunting 2 leads with a momentary button.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG FACEBOOK YOUTUBE FLICKR INSTAGRAM
Jump to top tom @ eas is offline   Reply With Quote
buttons, car, info, radio or telephone, steering, wheel, zcp
Replaced ZCP steering wheel with OEM Leather Multi Function. BUTTONS NO WORK!Help? thesilverm3guy E46 M3 (2001-2006) 11 Fri, Oct-17-2008 12:51:50 PM
Changing TWO Buttons on my steering wheel. R/T and the other one. Is it possible? jamesbond E46 M3 (2001-2006) 10 Tue, Aug-22-2006 10:37:21 AM
Unused steering wheel buttons Eastwwood E46 M3 (2001-2006) 1 Thu, Feb-16-2006 07:51:38 AM
Steering wheel buttons what are these for? brownie E46 M3 (2001-2006) 4 Wed, Oct-26-2005 03:37:59 AM
Looking for a Satellite Radio receiver that I can contro using the wheel buttons lozarus Audio/In Car Entertainment (I.C.E.) 5 Wed, Jun-01-2005 02:33:39 PM
Discussing Info on steering wheel radio/telephone buttons on a ZCP car in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
