Old Tue, Dec-10-2019, 05:35:53 PM   #21
Steve M3
Reputation: 0 Steve M3 is on a distinguished road
Default Re: S54 conversion muffler shootout
Great information, thanks for doing this.
Jump to top Steve M3 is offline   Reply With Quote
Old Tue, Dec-10-2019, 06:13:09 PM   #22
rbg
Reputation: 0 rbg is on a distinguished road
Originally Posted by GeorgeH View Post
Modified S2 with Dinan - 317.35/238.36
Modified S2 with BMW Performance - 315.56/238.16
Factory S2 with Stromung - 315.53/238.49
Modified S2 with 325 Muffler - 308.31/233.83
Modified S2 with No Muffler - 307.59/240.57
Modified S2 with 330 Muffler - 307.37/235.63
SuperSpring S2 & S3 Replacement - 306.48/235.32
Modified S2 with ZHP Muffler - 306.17/238.47
Modified S2 with E36 M3 Muffler - 304.23/236.41
Am I correct that Dinan muffler or bmw performance mufflers put ~10hp more that SS s2+s3 (on a stock tune I assume)?
Jump to top rbg is offline   Reply With Quote
Old Tue, Dec-10-2019, 06:52:40 PM   #23
Bimmerman325i
Beardface McMountainMan
Bimmerman325i's Avatar
Reputation: 0 Bimmerman325i is on a distinguished road
I'm honestly surprised you got such great numbers out of the E36 muffler/ S2 pipe; those parts on mine, with SS headers/Sec1, were 10whp less.
I bet that has a fair amount to do with how mine was welded together, but still, interesting results.
Another interesting data point would be the pipe OD on the replacement parts. Eg, OD of the SS setup, the BMW Perf, etc. Not much need on the Stromung since it's just a muffler.
1995 BMW M3/2/5-- S54/Mk60 California Smog Legal (Build Thread)
2017 Chevrolet SS, 6MT -- DD with burbly murrca
Jump to top Bimmerman325i is offline   Reply With Quote
Old Tue, Dec-10-2019, 06:52:50 PM   #24
To be clear, this is not their M3 muffleró this is their sedan/wagon s54 conversion muffler.
Old Tue, Dec-10-2019, 09:35:28 PM   #25
digger
Reputation: 0 digger is on a distinguished road
I'm still going through the data, but here's some info to start. Note: now that I have the files I realize with the correction factor being used at the dyno was set to STD which will read higher than SAE. I am correcting everything to SAE unless someone gives me evidence to the contrary.
Here is how the data was collected. We first started with the SuperSprint. We made a pull and the car put down 292.98/231.97 (HP/Tq). From there we cleared adaptations and made another pull, this time it did 300.73/232.79. From then on when we put a new muffler on we cleared adapatations and faults (the car never had any faults we just did it for consistency). The car was warmed up to operating temp and then a pull was made. After each pull we let the car cool down for 3 min before making the next pull. We repeated this until the power leveled off or started dropping. Some configurations we only pulled (3) times (never less though), others took 4 or 5.
Here's the initial order from highest to lowest HP output.
(Note: I will average all of the results over each run and then this may change slightly but this is the unofficial ranking as I know everyone wants to see these numbers and I'm not sure how soon I'll have everything fully compiled.)
The grouping is so close that I don't think there is a bad choice other than MAYBE the 325 muffler. The reason I say this is the 325 muffler had a noticeable whistle during a run we think it just couldn't handle the flow out the small tips. But also the power drastically dropped off on the 4th and 5th runs, maybe it was starting to overheat the exhaust or I don't know. I'm hoping someone might have a good theory on this.
325 runs:
1 - 303.06/234.11
2 - 307.06/234.28
3 - 308.31/233.83
4 - 301.57/233.86
5 - 299.03/233.44
***Another thing I noticed is the dyno graphs are going to 8400 and the car is still making power. The RPM was calculated by comparing the tach to the dyno drum rpm at various RPM. Looking at Dynojet's info it says the Torque is calculated using the engine RPM but looks like HP is purely a function of the drum, so it may mean nothing in the grand scheme of the data, but something to note.
are you going to post the graphs to?
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Old Tue, Dec-10-2019, 10:14:07 PM   #26
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
Yes, as Obioban pointed out this is a conversion muffler kit they sell. And to be honest it looks like they took their Non-M muffler and resonator kit and then made a section to adapt it to the M3 S1. My thought is this kit was not purpose built for the conversion but made to work as a conversion piece.
Yes, graphs, pictures, video and an excellent audio comparison is coming.
Current Garage... '00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT, '00 Black 323iT (wife's), '02 Alpine 325iT (Eileen, Track Wagon), '02 Japan Rot 325iT, '04 Gray 325iT, '04 IR ZHP Sedan
Instagram @ HillPerformanceBimmers
Email to George@HillPerformance.com
Jump to top GeorgeH is offline   Reply With Quote
Old Wed, Dec-11-2019, 02:00:17 AM   #27
digger
i'm wondering if there is anything obvious that you could measure that would account for differences. e.g. inlet pipe size, outlet pipe/tip size, construction type etc
1996 e36 M3 Evo
Old Wed, Dec-11-2019, 06:43:19 AM   #28
Definitely surprising for the BMW Performance muffler. Too bad it's discontinued.
Old Wed, Dec-11-2019, 07:42:40 PM   #29
10speed
Reputation: 0 10speed is on a distinguished road
Great thread! Good options for track guys trying to make light weight exhausts. I wonder how loud they are. Hmm..
Jump to top 10speed is offline   Reply With Quote
Discussing S54 conversion muffler shootout in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
