Old Thu, Mar-23-2017, 07:09:46 PM   #11
///MonkeyTech
Reputation: 0 ///MonkeyTech is on a distinguished road
Default Re: Front End Motor Leak (not TCT)
check the timing chain guide bolt between the thermostat and the cyl head. You can take a screwdriver and push it to see if its loose. If it is, and youve never done a thermostat, now is the time. Dont forget the water pump
Jump to top ///MonkeyTech is offline   Reply With Quote
Old Thu, Mar-23-2017, 09:26:17 PM   #12
BeyondM3
Reputation: 0 BeyondM3 is on a distinguished road
That's exactly what is loose. Thanks a million. Saved me from having to dump some dye in as I was debating that tonight.
Shame all of that has to come apart to tighten it back up....gonna look into doing it without removing so much....
Jump to top BeyondM3 is offline   Reply With Quote
Old Thu, Mar-23-2017, 10:09:17 PM   #13
PITT M3 RR
PA
PITT M3 RR's Avatar
Awesome - turned out OK
S54 E36 BUILD
Old Thu, Mar-23-2017, 11:31:25 PM   #14
BeyondM3
Originally Posted by PITT M3 RR View Post
Not that I know of, but if you're worried, dye it, find the leak then drain fix and fill! In the long run, it'll all be for the best.
Use a little mirror up under the vanos too, check as best you can around the front cover.
So far so good, thanks for the input.
I just drained some coolant, removed the housing and tightened the bolt up. Now I just have to wait to get some more of that glorious blue BMW coolant.
Discussing Front End Motor Leak (not TCT) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
