Old Mon, Mar-23-2009, 07:24:06 PM   #1
Ace M3
Reputation: 0 Ace M3 is on a distinguished road
Default Oil Temp Gauge stopped working!
I searched to no avail. Sorry if its been covered already.
Symptoms:
Oil temp gauge is all the way down as if the car was just turned on. This first happened when I was on the freeway, I looked down, temp gauge was all the way to the cold side, I got scared, started pulling over when the needle went back up to normal operating temp. I kept driving cautiously.
It did that intermittently for 2 days, until it just stopped working. Water temp gauge is fine, all other gauges work perfectly, but the oil temp gauge stays all the way down, even after 20 minutes of driving. Car has responded fine, acts normal.
Is this the gauge or the sensor? If anyone has gone through this and has some insight, I'd greatly appreciate.
TIA
Edwin - www.avuswebdesign.com
Jump to top Ace M3 is offline   Reply With Quote
Old Mon, Mar-23-2009, 10:20:24 PM   #2
Ace M3
bizzump. someone help!
Old Tue, Mar-24-2009, 02:10:46 AM   #3
davitaia
Reputation: 0 davitaia has a spectacular aura about
bump .
Jump to top davitaia is offline   Reply With Quote
Old Tue, Mar-24-2009, 02:44:00 AM   #4
kmurph
Reputation: 0 kmurph will become famous soon enough
Probably the Oil Levelling Sensor...I had the same issue. My oil temp gauge first started randomly not working...then it pretty much stopped all together.
I replaced the Oil Levelling Sensor which is at the bottom of the oil pan - Number 12 in the attached picture. It's been working ever since.
12 OIL LEVELLING SENSOR 1 12617508003
2007 Audi RS4 / GMG Exhaust
2001 BMW M3 - sold
Jump to top kmurph is offline   Reply With Quote
Old Mon, Sep-21-2009, 09:37:24 PM   #5
stock_S54
Reputation: 0 stock_S54 is on a distinguished road
I have the same problem...
I noticed a week ago that my oil temperature gauge wasn't working. It hasn't been working ever since.
Now when I start up the car, the yellow oil light illuminates for about ten seconds.
Will do the oil sensor replacement and see if it fixes the problem.
Jump to top stock_S54 is offline   Reply With Quote
Old Tue, Dec-22-2009, 09:03:26 PM   #6
autom8er
Reputation: 0 autom8er is on a distinguished road
Did this fix the problem? How much is the part at the stealership? Estimated time to repair?
Thanks,
-Ed
Jump to top autom8er is offline   Reply With Quote
Old Tue, Dec-22-2009, 10:49:23 PM   #7
kmurph
Thanks,
-Ed
Yes...it did fix the problem. My Oil Temp gauge has still been working. I can't remember how much the part cost. RealOEM.com has the part at $163.50. My guess is that my cost with a BMWCCA discount was $120-130.
http://www.realoem.com/bmw/showparts...11&fg=10&hl=43
As for the time it takes...the oil needs to be drained, and the aluminum thrust plate needs to be removed to access the bottom of the pan. Once you get get to the bottom of the oil pan, replacing the part takes a few minutes. You should be able to do it in less than an hour.
2001 BMW M3 - sold
Old Wed, Dec-23-2009, 04:22:47 PM   #8
autom8er
Thank you for the info..
Old Wed, Dec-23-2009, 06:18:07 PM   #9
M.Williams
Reputation: 0 M.Williams is on a distinguished road
I had the same problems and replaced the oil levelling sensor 2 weeks ago....problem solved for me as well.
Current - 01 LSB M3
Past - 95 M3 GTS-3 racecar
M3's are meant to be driven, everywhere....
Jump to top M.Williams is online now   Reply With Quote
Old Wed, Dec-23-2009, 11:20:32 PM   #10
SickSeries
Reputation: 0 SickSeries is on a distinguished road
Just ordered my sensor at rmeuropean.........was just over $100. Best price I found
Jump to top SickSeries is offline   Reply With Quote
gauge, oil, stopped, temp, working
oil temp gauge m3sparky E46 M3 (2001-2006) 4 Sat, Apr-21-2007 05:21:45 AM
Oil Temp Gauge not working what to look for? wrs1 Faults, Fixes and DIY 0 Fri, Nov-24-2006 07:30:19 PM
My Speedo & MPG Gauge Stopped Working Then Came Back. Zlatko E36 M3 (1992-1999) 9 Sat, Aug-05-2006 06:41:10 AM
E36 Gauge Panel w/VDO Boost, Oil Temp, Oil Pressure ESP Parts for Sale/Wanted 1 Wed, Mar-08-2006 10:32:13 PM
Oil Temp Gauge bnhs1210 E46 M3 (2001-2006) 6 Sun, Dec-28-2003 07:25:44 AM
Discussing Oil Temp Gauge stopped working! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
