Old Thu, Mar-23-2017, 02:14:56 PM   #11
M3po-428
Reputation: 0 M3po-428 is on a distinguished road
Default Re: Fan wont stop working after A/C and SAP delete
When I did my fan swap I had this 100% issue as well and it ended up being the fact that the sux fan is controlled by 2 things. Temp and then the little mentioned AC system pressure sensor that is located on the dryer/evaporator. When this is uplugged the fan runs at 100% so you can code that out. Use a spal temp switch or you could try to simulate it. But that is the reason its running at 100 percent.
Jump to top M3po-428 is offline   Reply With Quote
Discussing Fan wont stop working after A/C and SAP delete in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
