Old Fri, Sep-02-2016, 02:31:29 PM   #81
bimmerfan08
bimmerfan08's Avatar
Default Re: DIY: Oil pan removal + engine mounts
Originally Posted by Dermit View Post
Don't use RTV AND a gasket! I learned that the hard way with a Jeep transmission. Sucker leaked like a sieve once it was up to temperature! Per the scolding from the mechanics shop: use one or the other. I used the OEM gasket when I dropped the oil pan. No leaks here. I did put a bead of RTV over the two joints in the block per BMW manual. The bead went between the block and the gasket.
Originally Posted by Jfbsaratoga View Post
Manual says "non-hardening" gasket maker in the four corners. Is that rubber gasket dressing? Any suggestions?
This is what the tech at my local indy shop told me to do. RTV sealer in the corners only.
Old Fri, Sep-02-2016, 09:59:17 PM   #82
I only used RTV at the seams. No leaks as far as I can tell
Old Sat, Sep-03-2016, 02:57:59 PM   #83
stukreit
Reputation: 0 stukreit is on a distinguished road
Default A way to hold gaskets in position during reassembly
I have started using string to thread gaskets in place (ie to timing cover, will try with oil pan). Depending on the part, you need the end-most, corner, or sometimes center holes for first bolts on reassembly, so do not thread those.
Tie one end of the thread around the other, then pull tight and align the gasket.
Once the first bolts are in, cut the thread and remove it. Had a big Voila!
with the 2 wiggly gaskets on the timing cover on an m52 yesterday, looking
forward to same on an S54 oil pan next week.
Jump to top stukreit is offline   Reply With Quote
Old Sat, Sep-03-2016, 08:30:40 PM   #84
cyberlando
cyberlando's Avatar
Not gonna lie when I put my oil pan gasket back I put a thin layer of rtv all around it......no leak as of yet
Sent from my SM-N910F using Tapatalk
Engine:
Interior:
Suspension/Handling:
Old Sat, Sep-03-2016, 08:42:05 PM   #85
British-mark
British-mark's Avatar
Reputation: 0 British-mark is on a distinguished road
now thats what i call a DIY!
2003 BMW M3 E46 Convertible, Silver Grey Metallic A08
Mint! 37k Miles / TPI lug nuts / Macht Schnell studs / Tein Springs / Koni Shocks / ECS CSL brake upgrade / RE El Diablo / CSL Diffuser / Storm Gear surround / AFE charge pipe / AFE air scoops / Macht Schnell spacers / Extended paddle shifters / Depo tinted sides / Black out grills
Jump to top British-mark is offline   Reply With Quote
Old Thu, Sep-08-2016, 06:11:17 AM   #86
stukreit
Default Re: DIY: Oil pan removal + engine mounts: Vanos Tab Money Shot
It took me 4 hrs to replace the oil pan, engine mounts, and oil pan hoses. I am not a fast worker.
Old Thu, Sep-08-2016, 07:42:11 AM   #87
cyberlando
cyberlando's Avatar
The oil pan job for sure isn't for the faint of heart.......very involved.
Engine:
Interior:
Discussing DIY: Oil pan removal + engine mounts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
