Old Wed, Apr-13-2011, 05:20:53 PM   #41
roarf
Jimmies: Not Rustled
roarf's Avatar
Reputation: 0 roarf is on a distinguished road
Default Re: Another coolant temperature question
...At 80, the needle is just below vertical. The needle becomes fully vertical between 82-85 degrees Celsius, and from 86+ (which I do hit on occasion) it actually leans to the right.
Mine does exactly this as well. I just checked last night with the OBC menu up as I was driving. It was very steady at 81 deg. C as I was driving, with the needle at about the 11 o'clock position (maybe a tad higher). Maybe these gauges are just calibrated to be more sensitive than most cars.
I should also note that my coolant gets up to temp pretty quickly (as quickly as it should). I think if you are experiencing a stuck-open thermostat, it would take much longer for the coolant to get up to temp, if it can even get there.
'02 M5 - Carbon Black/Silverstone
'01 M3 - Imola Red/Black
Jump to top roarf is offline   Reply With Quote
Old Wed, Apr-13-2011, 06:09:20 PM   #42
krell
krell's Avatar
Reputation: 0 krell is on a distinguished road
I'm at a dealership right now for this problem, and they did indeed replace the thermostat. This also necessitated a coolant change, which someone was asking earlier if that was needed.
Jump to top krell is offline   Reply With Quote
Old Wed, Apr-13-2011, 06:26:30 PM   #43
jkman720
Reputation: 0 jkman720 is on a distinguished road
Originally Posted by BHenderson View Post
How far below noon is your needle? Have you checked your actual coolant temperature? Is your aux fan stuck on?
It ranges between the 1/4 mark (cold side) and noon.
How can I check the actual temp?
Aux fan seems okay per the newspaper test. (Looser when hot, stiffer when cold)
Jump to top jkman720 is offline   Reply With Quote
Old Wed, Apr-13-2011, 06:55:28 PM   #44
bolestuff
bolestuff's Avatar
Reputation: 0 bolestuff is on a distinguished road
Same issue, t-stat fixed it. Takes 15 minutes, just remember to refill with BMW coolant.
Carbon Black on IR = Hotness!
Jump to top bolestuff is offline   Reply With Quote
Old Wed, Apr-13-2011, 09:42:02 PM   #45
e4604
e4604's Avatar
Reputation: 0 e4604 is on a distinguished road
I had bought my car with 11k on it, I noticed it doing same thing I figured bad thermostat, replaced it and it does same exact thing so I don't know what's up
Jump to top e4604 is offline   Reply With Quote
Old Thu, Apr-14-2011, 05:36:45 PM   #46
NikolaiD
NikolaiD's Avatar
Bulgaria
http://www.m3forum.net/m3forum/showp...30&postcount=3
Option 7.0 gives you the coolant temperature where the trip odometer usually is.
MSS54 Error Codes
(work in progress)
Old Mon, Oct-10-2011, 10:00:30 AM   #47
streetracing
streetracing's Avatar
Reputation: 0 streetracing is on a distinguished road
Greece
Question Re: Another coolant temperature question
My water temperature gauge on the car operates for one year during winter. Between first left dot and middle during cruising at low speed.
I changed the thermostat in spring , everything was ok until august when one day with 30 c outside and ac on the water middle went a little on the left from the middle. Now that is 25 c and during my cruising at low speed the car s water temperature sits between first dot and middle. In traffic it is sit in the middle. Thermostat is 5 months old. I think that this is a normal thing. When it is cold outside and we are cruising at low speeds the niddle does go between first dot and middle
I also changed the water pump last July.
I do not know if this helps.
tuned by evolve
323 e/hp on MAHA
Jump to top streetracing is offline   Reply With Quote
Old Thu, Feb-02-2012, 09:34:21 PM   #48
kabalZA
Reputation: 0 kabalZA is on a distinguished road
South Africa
I just changed my thermostat, waterpump, fan clutch, temp sensor and 50/50 distilled water/bmw coolant.
first heat cycle to bleed air was not under load, just warmed the car to operating temp, then let it cool completely, and then bleed and topup reservoir.
today(tonight) I took it for a road test (about 20degrees C outside), and I have a similar "issue". under load the gauge (water) is at noon. but under cruising it would drop to say 11:30.
obvs it is possible that I still have some air, which I will bleed tomorrow, but I am pretty certain my cooling system is now in 100% condition, and the behaviour is normal???
Jump to top kabalZA is offline   Reply With Quote
Old Thu, Feb-02-2012, 10:59:16 PM   #49
bimmerfan08
bimmerfan08's Avatar
Originally Posted by deilenberger View Post
Your thermostat is shot. Running the engine at 126F is WAY cold, and will result in a very rich mixture going to the cylinders. That's not good since it tends to wash oil off the walls of the cylinders. The M3 thermostat is probably designed to run close to 220F or so - but BMW does change engine temperature to maximize efficiency. The water temp gage is buffered - meaning - what you see isn't what you have. BMW purposely makes it run at 12 noon so they don't get people complaining about the fluctuations in engine temp they use to maximize engine efficiency. If it's not at 12 noon - something is wrong. In this case - running cold - pretty much has to be the thermostat.
I dont think this post is entirely correct. Funny you mention the thermostat being shot if its not dead center. My temp guage has been just to the left of the noon mark all winter long. Just last Friday I had to replace my water pump and while in there put a brand new thermostat. I even flushed the coolant and used brand new coolant. The needle is just about in the same position when I drive. Ive noticed that in the cooler/colder months the temp needle sits just to the left of the noon position. I dont think theres anything wrong. Car runs normal.
Old Mon, Sep-11-2017, 02:39:02 AM   #50
BHenderson
Reputation: 0 BHenderson is on a distinguished road
You're fine if it's not dead center. I'm going to guess it's probably at around 86-88C if it's just to the left of noon. If it starts creeping up past noon, that's when you're in trouble (~92C, maybe? been a while).
I installed a sport fan clutch since these cars can't handle Texas weather (this is after a new radiator, stock fan clutch, waterpump, etc.).
Jump to top BHenderson is offline   Reply With Quote
coolant, question, temperature
Trackday Temperature (oil+coolant) M3Seeto M3 Track: Racing and DE 19 Sat, Aug-29-2015 08:45:09 PM
-coolant temperature removal-replacement- kewlwhip E46 M3 (2001-2006) 11 Wed, Mar-24-2010 03:29:10 AM
Question about temperature gauge? keep it boring E36 M3 (1992-1999) 26 Sun, Feb-18-2007 07:04:20 AM
Coolant Temperature Sensor GOALSTOPR E36 M3 (1992-1999) 17 Fri, Aug-18-2006 03:01:30 PM
Tire and Temperature Question Rhexis E46 M3 (2001-2006) 5 Sun, Nov-09-2003 11:37:56 PM
Discussing Another coolant temperature question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
