Old Fri, Oct-10-2008, 05:31:05 PM   #21
s2k2m3
s2k2m3's Avatar
Reputation: 0 s2k2m3 is on a distinguished road
it happend to me too. this should be a recall, coz i heard a lot of peeps with 3 series got this problem.
Jump to top s2k2m3 is offline   Reply With Quote
Old Fri, Oct-10-2008, 07:33:54 PM   #22
BlazenXLT
We've had one yes, what about second breakfast?
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
Mine does it too. It's only annoying when the idiot light comes on though, so I don't worry about it.
-It's kinda funny that there is a warning light for washer fluid. In my truck, if you hit the button and nothing comes out, it's empty.
Jump to top BlazenXLT is offline   Reply With Quote
Old Fri, Oct-10-2008, 07:41:41 PM   #23
BemuFLR555
Reputation: 0 BemuFLR555 is on a distinguished road
Happened to me too. I was annoyed so took off the fenderliner, found the little 90 degree elbow on top for a ventline (I assume) but no ventline attached. So I attached a rubberhose on to it and routed it up and problem solved.
Jump to top BemuFLR555 is offline   Reply With Quote
Old Sat, Oct-11-2008, 11:42:55 PM   #24
tilolite
tilolite's Avatar
Reputation: 0 tilolite is on a distinguished road
Haiti
I just fixed my windshield and headlight fluid sprayer which never worked since i bought the car 3 years ago. Living in AZ, i did not have to use it that often.
First, you don't need remove the front tire if you don't plan to remove the reservoir. It's best to turn the wheel completely to the right then remove all 6 screws holding the big plastic cover. Most leaks, like mine, occur where the pumps attached to the reservoirs. Pushing them deep in6 and ensure that everyting else is tight. If the leak is from the reservoir, then you have to remove the tire to get it out.
Jump to top tilolite is offline   Reply With Quote
Old Sun, Oct-12-2008, 07:36:35 PM   #25
RynoS54
wuuut wuuuuuut
RynoS54's Avatar
Reputation: 0 RynoS54 is on a distinguished road
I just fill as needed when the dash light goes on.....I'm too lazy to fix it eventhough I should....
CB/GREYandotherstuffs
Jump to top RynoS54 is offline   Reply With Quote
Old Mon, Oct-13-2008, 01:38:03 AM   #26
duff0000
///M
duff0000's Avatar
Reputation: 0 duff0000 is on a distinguished road
im in the club as well, just filled it up, looked at it 5 mins later and there was a little puddle coming from the pass side.
Jump to top duff0000 is offline   Reply With Quote
Old Fri, Nov-20-2009, 02:23:31 PM   #27
anti-roll
Reputation: 0 anti-roll is on a distinguished road
awesome, so I'm not alone
Jump to top anti-roll is offline   Reply With Quote
Old Fri, Nov-20-2009, 03:22:17 PM   #28
deilenberger
deilenberger's Avatar
You are being funny right?
Recalls are for safety related items that are likely to cause a crash. Not for rubber seals that may deteriorate just from age.
Mebbe things are different in Manila.
  • 2011 Lexus RX-350. SWMBO's toy.
Old Thu, Jan-21-2010, 10:25:38 PM   #29
GLTremendo
Dinan Stage1 - GL and Tremendo
Reputation: 0 GLTremendo is on a distinguished road
I have this problem now. The top part of the wheel well liner doesnt fit right when I tried to put it back and also I broke the plastic underneath and I cannot connect it correctly. F N A. I got no time for this nonsense, I think I may end up taking it to the stealership.
Jump to top GLTremendo is offline   Reply With Quote
Old Thu, Jan-21-2010, 10:41:39 PM   #30
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
if your water bottle is touching the liner, there are a few things i would check.
1. do you have the correct water bottle?
2. is it secured correctly?
3. is your bumper seated all the way back?
Tischer aka GetBmwParts
fluid, question, reservoir, washer, windshield
cracked washer fluid reservoir vs CPO so gti E46 M3 (2001-2006) 4 Sun, Mar-22-2009 10:57:50 PM
Question about the windshield wiper fluid reservoir... hdsr09 E46 M3 (2001-2006) 9 Thu, Apr-10-2008 11:58:38 PM
Is the M3 Windshield washer fluid>> Fstcmpny E46 M3 (2001-2006) 1 Thu, Jan-11-2007 09:26:38 PM
Windshield Washer Fluid w/ De-icer Caz E46 M3 (2001-2006) 1 Thu, Dec-08-2005 12:39:41 AM
WTB:windshield washer reservoir (Tank) Silver///M Parts for Sale/Wanted 10 Thu, Jul-14-2005 02:52:52 AM
Discussing Windshield Washer Fluid Reservoir question... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
