Old Sat, Nov-04-2017, 05:08:28 AM   #1
bigjae1976
Default Rod bearing pics - 2004 M3 motor w/93k miles
Never mind the broken exhaust hub...the bearings look good...for an S54.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sat, Nov-04-2017, 05:11:59 AM   #2
EricSMG
40 something
Default Re: Rod bearing pics - 2004 M3 motor w/93k miles
Look pretty good to me, about right.
Old Sat, Nov-04-2017, 05:23:37 AM   #3
mrgizmo04
mrgizmo04's Avatar
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Nov-04-2017, 05:32:45 AM   #4
bigjae1976
Not sure if you can tell but there is no copper showing. The journals looked good and all measured to .002 with plastigage. I think it supports my theory that doing the rod bearings between 80k-100k is about right.
Old Sat, Nov-04-2017, 05:35:07 AM   #5
mrgizmo04
mrgizmo04's Avatar
Yeah I was going to say, top row doesn't show any copper. Impressive.
I think most folks use blackstone analysis as a guide as to when to do it?
'05 M3 6MT coupe
Old Sat, Nov-04-2017, 05:41:28 AM   #6
bigjae1976
Might not help if you buy the car used but oil sampling every couple of oil changes to establish a history is a good approach.
Iíve gotten out of the habit of using oil analysis with my E90 M3. My e46 is a track car so I can yank the motor in 2-3 hours. Not much of a hassle to do rod bearings whenever.
Old Sat, Nov-04-2017, 05:43:50 AM   #7
mrgizmo04
mrgizmo04's Avatar
2-3 hours... How many do you go through a year?
'05 M3 6MT coupe
Old Sat, Nov-04-2017, 05:48:04 AM   #8
bigjae1976
I donít have AC, heater core, emissions equipment and a bunch of other stuff. Makes it way easier!
Disconnect the driveshaft, drain the oil and coolant, pull off the front end, drop the front subframe, remove the intake manifold and it pretty much just comes out.
Old Sat, Nov-04-2017, 03:34:06 PM   #9
M3_Pilot
I just changed mine last week with 135k miles on them. I reckon they could have lasted at least another 10k miles.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Mon, Nov-13-2017, 04:01:00 PM   #10
Dirty Elf
BSME
Dirty Elf's Avatar
Reputation: 0 Dirty Elf is on a distinguished road
replace with OEM, VAC? any other options?
First Road Trip
2004 Silver-Grey ///M3 Coupe
Jump to top Dirty Elf is offline   Reply With Quote
Discussing Rod bearing pics - 2004 M3 motor w/93k miles in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
