Old Mon, Jan-22-2007, 02:50:49 AM   #31
Idz21
JohnnyCakes
Idz21's Avatar
Reputation: 0 Idz21 is a jewel in the rough
Poland
lets see some track pics ktx
IIIM3 Interlagos Blue on Ecru
Options { ZCP-SMG-NAV-HFS-XHL }
Originally Posted by Beowoulf View Post
I give up, you win.
Originally Posted by azjimi View Post
I give up, you won.
Originally Posted by trebm3 View Post
you win.
Help M3Forum cure cancer!
Jump to top Idz21 is offline   Reply With Quote
Old Mon, Jan-22-2007, 03:08:51 AM   #32
nlpamg
mbworld spy
nlpamg's Avatar
Reputation: 0 nlpamg is on a distinguished road
that looks great! oem "time attacks!"
-Phil
Jump to top nlpamg is offline   Reply With Quote
Old Mon, Jan-22-2007, 03:13:02 AM   #33
spikek1
Reputation: 0 spikek1 is on a distinguished road
those are HOT wheels man
Jump to top spikek1 is offline   Reply With Quote
Old Mon, Jan-22-2007, 03:57:07 AM   #34
tuckersmg
tuckersmg's Avatar
Reputation: 0 tuckersmg is on a distinguished road
Two thumbs up wheels look good. Lets see pics on the car. What kind of splitters are you running?
Jump to top tuckersmg is offline   Reply With Quote
Old Mon, Jan-22-2007, 10:50:34 AM   #35
vorsteiner
Old Mon, Jan-22-2007, 12:17:06 PM   #36
odgaard
X_X
odgaard's Avatar
Reputation: 0 odgaard is on a distinguished road
that looks awesome....i might consider this when i get my 19's and use my 18's for winter wheels
Gruppe M | Autosolutions SSK | CSL trunk/diffusor |
Rotora BBK | Ground Control Coilovers
525f/600r
Jump to top odgaard is offline   Reply With Quote
Old Wed, Jan-24-2007, 12:41:43 AM   #37
rneily
Reputation: 0 rneily has disabled reputation
I dont mean to repeat myself from e46fan but will this setup work for Auto-X? Seems like it would be great to be able to get same size all around and be able to rotate?
Will these OEM18 Rears rub without suspension (ie stock?). What size tire could I run?
Jump to top rneily is offline   Reply With Quote
Old Wed, Jan-24-2007, 01:01:52 AM   #38
jacky72
M-Division
jacky72's Avatar
Reputation: 0 jacky72 is on a distinguished road
Doesnt the 9J +27 protrude alot outta the front fender?
I actually think this set up increases too much stressed on the wheel bearing coz essentially they are mounted too further from the axle.
Having said that, u hv done a great job. The rims look hot.
____________________________________
Current Ride : E90M3 The Cold Moon , Porsche CayenneS The Black Tanker
Previous Rides : '08 997GT3 Mk1, '03 E46M3, '03STi Spec C, '04 E85 3L
Jump to top jacky72 is offline   Reply With Quote
Old Wed, Jan-24-2007, 01:10:18 AM   #39
Red M3
Red M3's Avatar
Reputation: 0 Red M3 is on a distinguished road
Nice job. Looks good. Something different.
Jump to top Red M3 is offline   Reply With Quote
Old Wed, Jan-24-2007, 11:13:38 PM   #40
This would work quite well for autox setup. You will not rub with 265 for sure and I know 285 works with a little bit of negative camber (mad italian runs 285s on all 4 corners)... I'm 98% sure 275s will work on all 4 corners but I do need to try it still.
I'm actually going to pick up another set at some point (and powdercoat them in some other different way) and run 285 square for autox
They stick out about as much as my OEM 18 front with 12mm spacer (which I need for the brembos) on my snow setup
It certainly will create more stress on the wheel bearing, but no more so than any other wheel that you can run a square setup on.
oem, pics, powdercoated, real, setup, tone, track
FS: Square Setup Track Wheels -- (4) E46 M3 OEM 18x9 oh2fly Parts for Sale/Wanted 0 Sat, Mar-22-2008 08:19:19 PM
FS: 4 rear oem rims (track setup) maditalian Parts for Sale/Wanted 16 Thu, Aug-16-2007 01:24:28 PM
E39 (REAL) SSR GT3 Silver w/Polished Lip and tires (staggered setup)with pics RanGer498 Parts for Sale/Wanted 1 Wed, Feb-28-2007 06:44:13 PM
OEM 18s 2 tone powdercoated for track use Obioban E46 M3 (2001-2006) 14 Fri, Jan-19-2007 02:42:12 PM
Interested in an Interior Swap / Two Tone Setup? undertow E46 M3 (2001-2006) 1 Mon, Aug-23-2004 09:09:48 AM
Discussing Real pics of my 2 tone OEM 18 powdercoated track setup in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
