Old Tue, Aug-07-2018, 05:34:22 PM   #11
mrgizmo04
mrgizmo04's Avatar
Default Re: E46 M3 Diff (my journey)...
Originally Posted by rbg View Post
My diffsonline has clunk. I asked them to make it as tight as possible so clunk is way less than it was before. However there is a price for tighter assembly it whines more than stock when you of throttle at 60-80mph.
Yep, mine is tight and with poly bushings all around it whines...
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Aug-07-2018, 11:01:10 PM   #12
DNS2003M3
Reputation: 0 DNS2003M3 is on a distinguished road
My clunk was getting progressively worse, took it in Monday for evaluation and was given 2 options. 1 replace upper bushings and center section with alignment $5200. Option 2 upper bushings and rear cover to correct leak $800. I chose option 2, picked up car this evening and it is now as smooth as my 2014 F150 or the 2018 Mazda 3 I had for a rental.
Jump to top DNS2003M3 is offline   Reply With Quote
Old Wed, Aug-08-2018, 12:44:58 AM   #13
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
$800 for rear cover replacement, thatís a real steal
Topo Chico
Old Wed, Aug-08-2018, 01:13:53 PM   #14
JJCTHE1
JJCTHE1's Avatar
Reputation: 0 JJCTHE1 is on a distinguished road
My first E46 back in 2003 clunked from day one, I bought it pretty much new with about 3k miles on it. My second and current E46 had some seepage in the diff when I bought it, it was literally the only thing that came back on the PPI, it also had the typical clunk. So I replaced it with a Dinan performance diff and it does not clunk.
Jump to top JJCTHE1 is offline   Reply With Quote
Old Wed, Aug-08-2018, 09:43:23 PM   #15
e36 323ti
e36 323ti's Avatar
Reputation: 0 e36 323ti is on a distinguished road
Norway
New diff in, but first some doc of the old one...
The old diff had much more play on the right (passenger) side than the new (the new had virtually 0 play), but less on the driver side than the new. Seems like the play was tuned around comparing the new and the old. The largest play on the old one was ~2mm (1mm on the new).
Video of the old diff (with the Clunk?):
Probably nothing wrong with the old diff...
Learnt that we have to distinguish between the e46 m3 Clunk and the Clank.
With the diff out, it was kind of clear that my car had at least the Clank (which I believed was the famous Clunk).
Video of the Clank (sorry for the vertical video):
Jump to top e36 323ti is online now   Reply With Quote
Old Thu, Aug-09-2018, 06:44:41 AM   #16
e36 323ti
e36 323ti's Avatar
Norway
Had the first drive with the new diff. Definitely less Clunk, but the Clank is still there. Next step will be to replace the "constant velocity joint"...
Edit: Good post for the Clank: http://www.m3forum.net/m3forum/showthread.php?t=369047
Old Thu, Aug-09-2018, 11:30:11 AM   #17
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
I've been going through the same thing and noticed that my inner CV joints are pretty sloppy so I think that is part of the problem. Has anyone found a good source for CV joint replacements other than the $600 OE shafts?
Jump to top ctres is offline   Reply With Quote
Old Thu, Aug-09-2018, 11:49:21 AM   #18
BMW sells it without the shaft.
https://www.realoem.com/bmw/enUS/sho...diagId=26_0197
26117841003
FS: Custom Imola leather/alcantara steering wheel, with imola centering stripe
Old Sun, Aug-12-2018, 05:26:05 PM   #19
e36 323ti
e36 323ti's Avatar
Norway
The measured rotational play in both diffs:
EDIT: Added TSB info..
TSB: E46 M3 - "Clunk Noise" on Load Reversal
MODEL :E46 M3 with S54 engine
SITUATION
Customer may complain of a drivetrain rattle or knocking noise during a load change, e.g. 1st to 2nd gearshift at low engine speed, coming from the rear axle area. Further drivetrain checks reveal that the right side rear axle output flange appears to have more play (approximately 0.5mm to almost 1mm) when compared to the left side output flange.
INFORMATION
The radial play on the right side rear axle flange is a normal design characteristic of the new M differential lock style rear axle used on E46 M3 models. Therefore an M3 differential should not be replaced due to a difference in play (when comparing left to right side differential output flange play) since this will not eliminate a drivetrain rattle or knocking noise.
IMPORTANT
In order to transmit engine torque to the rear wheels instantaneously, without any time lag, the whole M3 power train was designed with maximum torsional rigidity. Consequently, the flywheel mass and its damping capability has been reduced to a minimum. As a result, during an abrupt torque transfer (e.g. 1st to 2nd gearshift at low engine speeds) driver receives an acoustic feedback, which can be interpreted as a "clunking or rattling" noise. This characteristic is common in many high performance vehicles. Activation of the "Sport Mode" offers an additional increase in driving dynamics. As a result, acoustic feedback from the power train may be even more pronounced. The acoustic feedback characteristic is not a symptom of a failure, and does not compromise long-term reliability of drivetrain components (clutch, transmission, differential), nor does it adversely affect performance of the vehicle.
WARRANTY INFORMATION
For information only.
From <http://www.m3forum.net/m3forum/showthread.php?t=379846>
Old Sun, Aug-12-2018, 07:07:36 PM   #20
ctres
ctres's Avatar
26117841003
Sorry, meant the CV joints on the axles, not the driveshaft.
Discussing E46 M3 Diff (my journey)... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
