Old Tue, Jun-18-2013, 12:07:00 AM   #1
BearDeXPS
BearDeXPS's Avatar
Question Overheating before/after complete cooling system replacement - Help Request
'05 w/ 85k miles. Prior to replacing the complete cooling system there was overheating. After replacement the same issue persists. Appears to "want" to overheat only on highway when driving spirited (not saying WOT). With A/C now turned off and driving in traffic or stop/go traffic at lower speeds the temp comes back down to just above normal operation temp. So at speed is when the overheating appears prevalent and heater ON is required to prevent critical overheating.
Only overheats in the S.Texas late afternoon drive home from work (>95 degrees). Does not overheat on my morning commute (<85 degrees).
Less than 500miles ago replaced every part of the cooling system w/ new OEM except as listed below from ECS & Tischer (not just because of this issue, but feel this is smart maintenance for its mileage):
- Water pump
- T-stat
- Fan clutch
- Fan clutch blade
- Expansion tank kit
- Aux fan switch
- Temp sensor
- Radiator *Mishimoto*
- OEM coolant used
- Heater hose
- all new bolts, o-rings, gaskets, washers, seal's, etc
*also all pulleys, belts, and tensioners were replaced w/ new OEM + EVOsport power pulleys
*OEM coolant used w/ 50:50 ratio distilled water (also tried removing more coolant and adding more water to achieve "Texas Mixture"... still no luck)
* the only thing not replaced was the upper and lower radiator hoses because Rogue Engineering is out of stock for their silicone hoses (and has been for months); their next batch is coming in the next few weeks and I'm at the top of their list... but this is irrelevant because the stock ones are not leaking. In fact, the whole system is not leaking and holding correct coolant levels.
* A/C blows cold, heat blows hot
* no lights, no codes
I do not feel there is an issue with any of the new installed parts because as stated above, this issues was present prior to the preventative maintenance cooling system overhaul. I think the next step is to check for any calibration issues between the Fan Switch and ECU or maybe Temp Sensor and ECU - meter wires and also get real time telemetry.
It's only going to get hotter down here in Texas so if anyone has any recommendations or has had a similar situation/solution please let me know! TIA
Last edited by BearDeXPS; Tue, Jun-18-2013 at 02:00:34 AM. Reason: think -> thing, silcon -> silicone (derp)
Old Tue, Jun-18-2013, 12:11:03 AM   #2
bzsbimmer
Reputation: 0 bzsbimmer is on a distinguished road
South Korea
Default Re: Overheating before/after complete cooling system replacement - Help Request
Have you properly bled the coolant system?
Helping the economy one mod at a time
Alpine E90 M3
Jump to top bzsbimmer is offline   Reply With Quote
Old Tue, Jun-18-2013, 12:15:55 AM   #3
BearDeXPS
BearDeXPS's Avatar
Twice.
The first time when completing the system. The second when trying the more distilled water ratio mixture -> "Texas Mixture"
Old Tue, Jun-18-2013, 12:36:39 AM   #4
KINGAMR
Retro Schnitzer Junkie
KINGAMR's Avatar
Reputation: 0 KINGAMR is on a distinguished road
My car had the same exact symptoms last summer before replacing the clutch fan.
03 M3 AW/IR, VFE 570 with upgraded SI impeller (tuned by Evolve 477WHP), SS Headers, CPI Sec1, Scorpion Muffler, PSS9, ARC8's + CF goodies Instagram @kings5x
Jump to top KINGAMR is offline   Reply With Quote
Old Tue, Jun-18-2013, 12:40:42 AM   #5
monochrom3
P-Car Noob
monochrom3's Avatar
Reputation: 0 monochrom3 has disabled reputation
Interesting... was there any air the second time? Perhaps hoses have cracks allowing air in, but then again, you might see a leak if that were the case.
e36 M3: Cosmos black, 99% track prepped (track toy)
981 GT4: Carrara White Metallic, clear side markers and some clear bra (because GT4)
MKV GTI: Black Magic Pearl, 4-Door, DSG, APR Stage 1, Omanyt (R32) wheels, Wolfsburg front end (daily driver)
e46 M3: TiAg, ESS VT450, Dinan 3.91's, Euro headers/cats, SS x-pipe, SS race muffler; GC coilovers & swaybar; Stoptech ST60/40; OEM CSL bootlid, Dinan 19's (sold)
997.2 GT3: Carrara White, no mods necessary (sold)
Jump to top monochrom3 is offline   Reply With Quote
Old Tue, Jun-18-2013, 12:48:23 AM   #6
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
bleed again.. did you test thermostat before installing?
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. Sold
1970 911T Tangerine
1972 911T Albert Blue
1970 911E Ossi Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Tue, Jun-18-2013, 02:16:07 AM   #7
BearDeXPS
BearDeXPS's Avatar
Fan clutch was replaced.. as stated above
During the original system replacement the one damn thing I forgot to purchase was the fan switch... so when replacing that a few days later we lost some of the fluid. But that was okay because we wanted to go with a more distilled water to coolant ratio mixture. So yes, there was inevitably some more air in the system... which was bleed.
Prior to install I bent over to check the thermostat... everything felt good to me
seriously though, how do you check the thermostat prior to install? Never heard of that.
How many time(s) would you expect I would need to bleed the system? How many gal of fluid would you think is required. I've already wasted 2gal ($40+) in OEM coolant trying to flush this thing.
^^^that's including watching a bunch of it hit the pan after the last bubble was seen (maybe 1/2 - 1gal)
Old Tue, Jun-18-2013, 02:33:09 AM   #8
eson
eson's Avatar
Reputation: 0 eson is on a distinguished road
Obviously not the reason for your overheating, but I have the EvoSport pulleys and they tend to make the car run just a bit hotter. Subscribed though, interested to see the outcome. Sorry I don't have much good advice -- good luck!
Jump to top eson is offline   Reply With Quote
Old Tue, Jun-18-2013, 02:41:27 AM   #9
JDayAU
JDayAU's Avatar
Reputation: 0 JDayAU is on a distinguished road
Install obd2 bluetooth connector and download torque application on the google play market
Monitor the temps that the ECU is getting from the temp sensor. I hate those dummy gauges cause they monitor a range.
My last car temp gauge was going crazy and once I started monitoring the sensor temps everything was good. Just a thought...
I have a old android phone dedicated to monitoring alot of the stuff the ecu monitors thru sensors
Jump to top JDayAU is offline   Reply With Quote
Old Tue, Jun-18-2013, 03:03:59 AM   #10
Moosecakes
Moosecakes's Avatar
Reputation: 0 Moosecakes is on a distinguished road
Our gauges aren't dummy gauges from what I've read... my car will fluctuate between right past the first dot and 12o'clock position based on driving conditions. street/freeway etc.
But if he is literally overheating and throwing the needle all the way over, there is an issue.
OP, what I would suggest is flushing your entire cooling system again, 100%, rad drained, block drained, and then flush it. Refill the system with the OE mixture and bleed it again, you need to have NO fluid or bubbles coming out of your bleeder screw. Make sure when you bleed the car you have the heater turned all the way up and the fan up to ensure no air is left in the heater core system.
I had this issue with my old 330ci, it just bled and bled and bled and I was starting to think wtf is going on but it finally stopped and I had no issues. I hope this helps you out man.
oh hey, I know you said that you are 100% positive there is no leaks, but did you pressure test the system to give you solid evidence of no leaks?
///M
________________________________________
| Tiag SMG to 6mt Build |
Jump to top Moosecakes is offline   Reply With Quote
Discussing Overheating before/after complete cooling system replacement - Help Request in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
