Old Mon, Oct-12-2009, 05:28:08 AM   #1
yellow_m3
yellow_m3's Avatar
Reputation: 0 yellow_m3 is on a distinguished road
Default VIS CSL Trunk lock fitment issue
I just installed a VIS CSL truck and the lock fitment is terrible. It's sunken into the trunk very far and it's off to one side. When adjusted properly in the keyhole there is considerable pressure on the fiberglass. The mounting hole does not have enough space to oval out to proper adjustment either.
Has anybody with a VIS trunk seen this issue and resolved it? If so, how?
Also, does the gap between the trunk and the body appear excessive?
Thanks for any help or advice.
Jump to top yellow_m3 is offline   Reply With Quote
Old Mon, Oct-12-2009, 05:54:09 AM   #2
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
i know a way to align the key cylinder to fit in the center of the hole. but... the opening itself just looks awful. the opening is not even a circle. that means the grommet may have issues trying to stay on.
Tischer aka GetBmwParts
Old Mon, Oct-12-2009, 06:40:47 AM   #3
yellow_m3
yellow_m3's Avatar
I can rework the hole to look like a circle, I didn't get that far because of how poorly the lock lines up. Once I have the lock close to the center, I'll fix the hole. What do I do to get the lock closer to center?
Old Mon, Oct-12-2009, 08:13:51 AM   #4
daytonaviolet
OEM CSL Whoore
what i've done in the past is to cut out the bracket that holds the key lock cylinder. once its cut out, locate it centered in the hole. use some tape to hold it in place, then use some epoxy or fiber glass to secure it back on the back side of the trunk.
Old Mon, Oct-12-2009, 03:37:18 PM   #5
Sman139
wheel wh*re in the making
Sman139's Avatar
Reputation: 0 Sman139 is on a distinguished road
i had the same issue when i installed my VIS. I had to dremel some fiberglass out of the way so that the cylinder can sit flush with the trunk
2003 ///M3 6sp. CB/Cinnamon
Gone
/// TC Kline /// Rogue Engineering /// Vorsteiner /// DICE /// Depo ///
"This is the best car and always will be and there is no point in thinking otherwise"
-Jeremy Clarkson
Jump to top Sman139 is offline   Reply With Quote
Old Mon, Oct-12-2009, 05:03:34 PM   #6
yellow_m3
yellow_m3's Avatar
That's a good idea. My only concern would be if I want to the stock trunklid back on the car.
Old Mon, Oct-12-2009, 05:05:45 PM   #7
yellow_m3
yellow_m3's Avatar
I dremeled the mount as much as I could. The problem is that the mount was not properly placed from the factory. It's too far away from the trunk itself. I suppose I could cut the base off, get it in the right place, and reglass it into place.
Now I fully understand why people recommend the real thing.
Old Mon, Oct-12-2009, 05:52:00 PM   #8
daytonaviolet
OEM CSL Whoore
after relocating the framing for the key cylinder, the key cylinder should still be able to come out of the framing if and when you decide to go to stock. basicly your just re-alining the entire key cylinder framing since the manufacturer didnt get it right.
Old Mon, Oct-12-2009, 06:47:53 PM   #9
yellow_m3
yellow_m3's Avatar
I misunderstood what you were saying originally. So, I should cut out the entire frame, position it properly, secure it in place with tape and cardboard and then glass it?
Old Mon, Oct-12-2009, 06:52:04 PM   #10
avusbluem3
avusbluem3's Avatar
Reputation: 0 avusbluem3 has disabled reputation
Thanks for the tip. Mine is centered but a bit too far in. My lock cylinder needs to come out about 1/4 of an inch. Going to have to give this a try.
95 E36 M3 Avusblue/Dove Gray :Sold
02 E46 M3 Steel Grey/Black Nappa/SMG II
Jump to top avusbluem3 is offline   Reply With Quote
csl, fitment, issue, lock, trunk, vis
Discussing VIS CSL Trunk lock fitment issue in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
