Old Wed, May-22-2019, 12:20:47 PM   #1
jagga
Reputation: 0 jagga is on a distinguished road
United Kingdom
Default Schrick 284 e36 m3 evo launch video
My e36 m3 evolution launch.....and before i get slagged off for driving downhill the road is dead flat. relevant mods s50b32 schrick 284 cams, stock ecu fueling not right needs a remap but still eats e46 m3 for breakfast lol, uprated injectors, eisenmann race exhaust with dtm tips 86mm, quickshift gear linkage,viscous delete, aluminium rad and larger oil cooler, full vanos rebuild,shims done, oem big end shells and arp bolts,all new oem engine sensors,Maf, coil packs,lamda sensors,cam n crank sensors,tps,cts sensor on engine. lightened and balanced flywheel with m5 clutch, fully rebuilt 3.62 low ratio diff, kwv3 coilovers, H&R adjustable anti roll bars,full nut n bolt suspension rebuild with full poly bush, Ferrari f40 brembo GT calipers on front porsche 996 brembos on rear with e46 m3 csl floating discs all round,Racelogic digital traction and launch control etc etc finally after a lot of effort got her running spot on so its time to fit the mac motoren carbon airbox and ring chip wizards for a remap.
Jump to top jagga is offline   Reply With Quote
Old Wed, May-22-2019, 01:44:38 PM   #2
Gregarious7
Reputation: 0 Gregarious7 is on a distinguished road
Default Re: Schrick 284 e36 m3 evo launch video
Nice. I'd love to hear it from the outside!
Jump to top Gregarious7 is offline   Reply With Quote
Old Wed, May-22-2019, 03:00:49 PM   #3
propcar
propcar's Avatar
Reputation: 0 propcar is on a distinguished road
oh that sounds nice....
Jump to top propcar is offline   Reply With Quote
Old Wed, May-22-2019, 03:29:24 PM   #4
jagga
United Kingdom
no problem i will get one done tonight, it sounds awesome from outside but will sound better once the mac motoren carbon airbox is fitted.
Old Wed, May-22-2019, 03:32:05 PM   #5
fattycharged
can't even
fattycharged's Avatar
Reputation: 0 fattycharged has disabled reputation
Zimbabwe
cool vert
Topo Chico
Jump to top fattycharged is offline   Reply With Quote
Old Wed, May-22-2019, 10:43:25 PM   #6
Kirbius
Kirbius's Avatar
Reputation: 0 Kirbius is on a distinguished road
Mac sounds to about 5000rpm few blips to 7000, standalone dyno tuning is happening in 2wks so will have more soon running at 100%. Just be aware OE ecu reflashes arent particularly great and it struggled to keep fuel and would run lean up top with this amount of air
Sent from my SM-G930F using Tapatalk
1996 Evo S50B32 - Boston Green on Modena - Slicktop - Al doors - PDC - JBR 5kg F/W - Clutchmasters FX400 - Mason SS Clutch pedal - UUC Evo3 SSK w/DSSR - PWR radiator - DrVanos o/haul - Full AKG 75D bushing & mount set - AP delete - Fan delete - X-brace - BC Racing C/Os 8k/10k - Whiteline 27mm ARB - ARC8 17x8.5 - Kumho V70A - APEX 75mm stud - Walbro GSS342 - Schroth Harness - TMS rear control arms - GT splitter - AP Racing CP8350 - Massive 332x32 - GT 4pc wing - Momo Monte Carlo - Racechrono TS - RR Strut Brace - Proflow PS res + AN lines - VDO gaugeset - E46 330 rack - VAC oil pump upgrade - ARP hardware - Magnaflow spun cats - MAC Motoren Airbox - AlphaN - ATI/VAC HB - 3.91 210 - ECUMaster Black + logger -
Jump to top Kirbius is offline   Reply With Quote
Old Thu, May-23-2019, 12:14:22 PM   #7
jagga
United Kingdom
nice motor very clean, i am just in the process of buying a vems ecu and getting her booked for a dyno remap
Old Thu, May-23-2019, 04:48:40 PM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Well done mate.
Old Thu, May-23-2019, 08:13:15 PM   #9
jagga
United Kingdom
just purchased this https://www.pnpecu.com/vems-s50b32-pnp-kit-7-p.asp
Kit consists of
VEMS 88pin Motronic PNP
VEMS 400kpa MAP sensor (capable of 3bar boost (43psi boost))
Bosch LSU 4.9 Wideband sensor and extra wiring. No controller required ($150 saving)
Bosch air temp sensor and a patch cable to extend to the original air temp connector. ( The standard sensor is not fast enough to use in a speed density system). This will not fit in the OEM location and should be fitted somewhere prior to your throttle body
Base map for a standard engine
once it arrives i will fit the wideband o2 sensor, ecu, map sensor, air temperature sensor and mac motoren airbox then its time for a remap, cant wait to finish her off and taste the fruits of my labour.
Old Thu, May-23-2019, 08:20:19 PM   #10
jagga
United Kingdom
https://youtu.be/y1fGJY2CVtA
https://youtu.be/RUfFJp7fV5g
which standalone ecu are you going to use?
i cant wait to get this done and taste the fruits of my labour.
Discussing Schrick 284 e36 m3 evo launch video in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
