Old Mon, Apr-15-2019, 04:15:06 AM   #121
bimmerdriver
Reputation: 0 bimmerdriver is on a distinguished road
Default Re: The ENGINE Thread
Originally Posted by EKaru View Post
Everything he said applies to V12 engines also. The root note is straight-forward for an even firing engine, but it's more complicated for an engine that isn't even firing. Whether the crankshaft is cross plane or flat-plane also has an effect on the root note.
2002 (12/2001) M3 6MT Coupe Carbon Black on Black - ZCP/CSL Wheels, 245/35/19 Mich PS2 & 285/30/19 Conti ExtremeContact DW, H&R 15 mm Front Spacers, CSL F/R Brakes, EBC Redstuff, TMS SS F/R Brake Lines, PSS9, TMS F/R Sway Bars, TMS Rear Control Arms, TMS Underdrive Pulleys, TMS/Carbonio Intake, Eisenmann Exhaust, AutoSolutions 30% SSK, BMW Illuminated Shift Knob, BMW Performance Pedals, BMW Performance 4.10 R&P, CDV Delete, Flossmann GTR Carbon Fiber Hood/Trunk, Carbon Fiber Rear Diffuser, Euro Front Signal Lights, Euro Rear Tail Lights, Angel Eyes, Homelink
1997 328is 5MT Coupe Madeira Violet on Black - Staggered M Forged Double Spoke Wheels, Bilstein Sport, H&R Sport, M Tech Rear Spoiler (Sold)
Jump to top bimmerdriver is offline   Reply With Quote
Old Sun, Apr-21-2019, 02:03:50 PM   #122
EKaru
EKaru's Avatar
Reputation: 766 EKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru Porsha
https://jalopnik.com/bmw-engines-are...hit-1784684330
Jump to top EKaru is offline   Reply With Quote
Old Sun, Apr-21-2019, 03:53:37 PM   #123
e46Dawg
e46Dawg's Avatar
Reputation: 0 e46Dawg is a jewel in the rough
Lol. Some truth in there.
Jump to top e46Dawg is offline   Reply With Quote
Old Sun, Apr-21-2019, 04:11:00 PM   #124
keca10
Useful Posts: 5
keca10's Avatar
Reputation: 0 keca10 is a jewel in the rough
I never had any issues with my M3 or M5 or X5 M.
Oh wait. Never mind. All 3 left me stranded and two needed new engines (I was able to limp the X5 to the dealer). All due to mfg defects (poor quality control) - bad iron block casting on the S54 (ded at 40k miles, 2005 build), bad fuel injector batch on S85 (deaded at 60ish miles if I remember right). X5 M needed new injectors around 40k miles.
Yet I still contemplate getting an X3 M
Jump to top keca10 is offline   Reply With Quote
Old Sun, Apr-21-2019, 04:44:31 PM   #125
m3 hal
Reputation: 0 m3 hal will become famous soon enough
The E46 M3 radiator doesn't belong in that article. Rod bearings weren't an issue beyond those engines affected by the recall. CCV failures and hard starting are also suspect. The E46 M3's biggest issues by far were the intake cam gear bolts, VANOS hub on the exhaust cam, and rear subframe mounting areas.
That aside, it is interesting how many M engines have some unique issue that leads to engine failure, usually just after the standard warranty period.
Jump to top m3 hal is offline   Reply With Quote
Old Sun, Apr-21-2019, 06:28:33 PM   #126
e46Dawg
e46Dawg's Avatar
^ Doesn't the s54 require rod bearing replacement at about 100k miles?
The article is definitely click bait, but these engines do have issues.
Old Sun, Apr-21-2019, 07:43:04 PM   #127
m3 hal
The bearings in the DIY on this site were changed at 130k miles and still looked pretty good. Depends on where you subjectively want to draw the line, but I don't consider +100k miles on rod bearings in an 8000 rpm engine to be on the same level as E92 rod bearings, or congruent with the point the article is making. The E46 bearing clearance itself is acceptable as I understand it, whereas the E92 and E60 is tighter than traditional rule-of-thumb for bearing clearance as a function of crank journal diameter.
Certainly, but some of those things (e.g. E46 M3 radiator) simply don't belong.
Old Sun, Apr-21-2019, 09:24:07 PM   #128
e46Dawg
e46Dawg's Avatar
Agreed that there is a difference between having to change rod bearings at 100k+ miles and having them flat out fail at low mileage. Also agreed on the e46 radiator. BMW cooling systems could be a completely separate rant.
It is funny though when you start thinking about all these engines and their unique problems.
Old Sun, Apr-21-2019, 09:33:07 PM   #129
Yeah, the E46 M3 really doesn't deserve a bad reputation for its cooling system. It's inheriting that reputation from the non-M -- people assume the M will automatically be more prone to failure.
No argument on VANOS or subframe/racp though. BMW dropped the ball there.
Old Sun, Apr-21-2019, 10:06:29 PM   #130
jph28
Back in 'Merica
Reputation: 0 jph28 is on a distinguished road
Lolíd a bit at that article. A few good points buried in such hyperbole that I think the author is doing himself a disservice (granted: clickbait).
Iím sure one of these could be written about any performance car manufacturer (except maybe Honda back in the day?)
Current - 2018 M2, 2018 Tahoe
2004 SilverGrey 6MT Sold
Past - '15 F31d / '02 M5 / '04 M3 / '12 VW JSW TDI / '91 Saab 900TC / '98 M3 / '06 WRX / '98 ITR / '88 Saab 9000T
Jump to top jph28 is offline   Reply With Quote
engine, thread
The engine weight thread EKaru Off Topic 42 Tue, Dec-23-2014 11:14:02 PM
65% thread Front/100% thread on tires, Is it going to be fine? enuff4speed E46 M3 (2001-2006) 13 Thu, Mar-01-2007 02:57:40 PM
Please dont Ban this thread, I need this thread or I wont be able to live DaBossIzHere E46 M3 (2001-2006) 83 Wed, Feb-01-2006 03:37:28 PM
Yet another check engine/02 sensor thread g60roddo E36 M3 (1992-1999) 6 Sun, Nov-27-2005 06:31:11 PM
What happened to the pinned thread on the '02 engine service action? Art Member Notes and Requests to Admin/Mods 2 Tue, Feb-03-2004 09:11:30 PM
Discussing The ENGINE Thread in the Off Topic Forum - Place to discuss this and that. Note: We also have "request to join" forums: Guns and Fitness.
