Old Wed, Aug-06-2014, 06:01:02 AM   #31
slbran02
Reputation: 0 slbran02 is on a distinguished road
Default Re: DIY: E46 M3 (S54) detailed valve adjustment
Great write up!!! Just finished it, took a little longer than expected but everything i needed was in your write up.
Jump to top slbran02 is offline   Reply With Quote
Old Wed, Aug-27-2014, 05:16:52 AM   #32
cobra2326
Reputation: 0 cobra2326 is on a distinguished road
Just wanted to comment that replacement of most of the gaskets is not necessary. Quoting from http://www.beisansystems.com/procedu...procedure.htm:
Note: S54 engine valve cover gaskets and bolt grommets, except front two corner grommets, are made from Viton and thus do not wear and need replacement. Valve cover front two corner grommets are Buna and thus wear and need replacement. They are included in the above list.
The two front grommets are P/N 11-12-1-437-395.
Jump to top cobra2326 is offline   Reply With Quote
Old Wed, Sep-03-2014, 08:00:57 PM   #33
Dino81
Reputation: 0 Dino81 is on a distinguished road
Wanted to tell you THANK YOU for taking your time to help the community. Just finished mine and followed this post. I (we) appreciate it!
Jump to top Dino81 is offline   Reply With Quote
Old Sat, Nov-15-2014, 10:08:56 PM   #34
Edgy
Constantly Learning M3 and M5 Owner
Edgy's Avatar
Reputation: 0 Edgy is on a distinguished road
Thanks -- subscribed.
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Jump to top Edgy is offline   Reply With Quote
Old Fri, Nov-28-2014, 06:00:09 AM   #35
71Kev
71Kev's Avatar
Reputation: 0 71Kev is on a distinguished road
Thank you. I'm adjusting my valves and changing the cooling system parts tomorrow.
Jump to top 71Kev is offline   Reply With Quote
Old Sun, Jan-04-2015, 05:28:09 PM   #36
jtt777
jtt777's Avatar
Reputation: 0 jtt777 is on a distinguished road
Thanks for the great DIY. This was a huge help to me!! I just did it this weekend, don't think I had an issues. I almost lost one shim, i realized its better to release the new shims off of the tool by moving the tool perpendicular to the camshaft. If you move the tool parallel to the camshaft, it's likely to flip even if you are slow and careful.
I actually did a time lapse of taking it all apart and doing the adjustment. (didn't time lapse putting it back together though!)
Thanks again!
2004 PY BMW M3
Jump to top jtt777 is offline   Reply With Quote
Old Tue, Mar-24-2015, 12:07:08 AM   #37
Bullitt544
Bullitt544's Avatar
Reputation: 0 Bullitt544 is on a distinguished road
Very nice write up! I will definitely be referencing this when I do my valve adjustment in the coming weeks. Thank you for taking the time to do this!
"Speed has never once killed anybody. Suddenly becoming stationary, that's what gets you."-Jeremy Clarkson
AP Racing V2 Headers///RE El-Diablo Track///Apex Arc-8 18x9.5 et35///ST Coilovers///Vorshlag Camber Plates
///SGT CSL Lip///
Jump to top Bullitt544 is offline   Reply With Quote
Old Fri, Apr-17-2015, 11:35:37 PM   #38
abigu
Reputation: 0 abigu is on a distinguished road
Hello,
I would like to request your help with a problem I ran into while working on my m3.
I followed this tutorial step by step and I am currently at step 45 where it says to rotate the crankshaft clock wise for cam lobes alignment.
The problem is that my crankshaft only rotates 1/2 a turn and then opposes resistance and goes back to is initial position. So it does not go anywhere.
I want to mention that my car is currently parked on ramps, oil was emptied, parked in 1st gear and with the handbrake on. It is an MSG.
Any ideas?
Jump to top abigu is offline   Reply With Quote
Old Sat, Apr-18-2015, 12:28:37 AM   #39
PITT M3 RR
PA
PITT M3 RR's Avatar
Put it in neutral?
S54 E36 BUILD
Old Mon, Apr-20-2015, 11:09:49 PM   #40
abigu
Smile Re: DIY: E46 M3 (S54) detailed valve adjustment
Originally Posted by PITT M3 RR View Post
Put it in neutral?
Thank you! I followed the instructions and was able to complete the valves adjustment. I also put in new spark plugs, ignition coils and changed the oil.
Waiting for my next adventure working on this car.
Discussing DIY: E46 M3 (S54) detailed valve adjustment in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
