Old Thu, Apr-19-2012, 03:02:25 PM   #11
bimmerfan08
bimmerfan08's Avatar
Default Re: DIY: E46 M3 detailed ignition coil replacement and spark plug replacement
Originally Posted by emanresu View Post
Thank you so much for this!
Three (probably dumb) questions:
1) I'm not very experienced in auto DIY, and I didn't really understand what you meant when you said I should have the battery hooked up to the power supply of the car if I want to do an ignition coil test. Does that just mean the battery has to be connected like usual?
2) Will it be dangerous if I unhook the cylinders with the battery connected and the car on?
3) Can I switch the ignition coils between cylinders with the battery connected and the car off?
As you can see, I'm very scared of the battery :p
Thanks a lot guys!
Originally Posted by Dont Try To Run View Post
I absolutely love how detailed you are... thank you. That makes me much more comfortable with taking off my valve cover and doing all of this myself! Thank you!
Thanks guys. The battery is not hard to disconnect. You won't be shocked provided you don't touch the two terminals together with something metallic while disconnecting it. Remember you only have to disconnect the negative terminal. I just do it as a safety precaution for all things electrical but you will need it to be comnected when you do the coil test. The car will be fine with the engine cover off and the battery still plugged in.
"The most difficult part of figuring out a car, the engineering, has been accomplished. Repairs and maintenance are simply dissembling parts and reassembling them." - bimmerfan08
Old Sun, Apr-22-2012, 05:42:05 AM   #12
emanresu
Reputation: 0 emanresu is on a distinguished road
Originally Posted by prematureapex View Post
Not an issue. Most people plug and unplug them with the car running to diagnose a failed coil.
I usually find the bad one with it running, swap it out while it's running, then shut it off, and restart.
I've found the new coil will not if you install it when the engine is running. Needs an ignition cycle to jump online.
Thanks for the info!
So after I disconnect it, it's ok to touch the negative terminal? What about before it's disconnected, but the car is off (I would never do it, but you never know)?
Jump to top emanresu is offline   Reply With Quote
Old Mon, Apr-23-2012, 01:50:59 AM   #13
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
if you get that far send out the injectors to get them cleaned/calibrated. Mine were way off and now it runs smooth…http://www.witchhunter.com/ lots of companies out there to choose from..
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. Sold
1970 911T Tangerine
1972 911T Albert Blue
1970 911E Ossi Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Tue, Jun-26-2012, 04:57:13 AM   #14
bimmerfan08
What's involved in calibrating the injectors and what's an average cost?
Old Wed, Jul-04-2012, 01:40:13 AM   #15
gzip01
Reputation: 0 gzip01 is on a distinguished road
Can we please remove the part where you suggest people buying the NGK DCPR8EIX Iridium IX spark plugs. Ive read many posts and how some of them break really easily. I would suggest only the OEM spark plugs as the iridium have caused me to break my wallet.
These were my results. I followed everything exactly.
Jump to top gzip01 is offline   Reply With Quote
Old Sat, Jul-28-2012, 06:43:37 PM   #16
bimmerfan08
Did you overtorque them? Both plugs are made by NGK just as an fyi.
Old Sat, Feb-22-2014, 06:10:21 AM   #17
normcaldwell
Reputation: 0 normcaldwell has a spectacular aura about
Appreciate the DIY.
Nice tip in step #20 to use a screwdriver for leverage in pulling out the coil pack.
Jump to top normcaldwell is offline   Reply With Quote
Old Sun, Apr-20-2014, 06:29:34 AM   #18
cell21633
Black Ops
cell21633's Avatar
Reputation: 0 cell21633 is on a distinguished road
just FYI, NGK recommends against using anti-seize on their plated plugs.
of course, there are different schools of thought for and against, but this is NGK's recommendation.
http://www.ngksparkplugs.com/pdf/tb-...1antisieze.pdf
Jump to top cell21633 is offline   Reply With Quote
Old Mon, Apr-21-2014, 02:53:23 PM   #19
bimmerfan08
Hmm makes sense. Anti-seize is not usually recommended for coated or torque-to-yield fasteners. I'll have to throw a note in there.
Old Wed, Sep-11-2019, 03:15:45 PM   #20
Robert's_BMW
Reputation: 0 Robert's_BMW is on a distinguished road
This is a great DIY, I am just letting the OP know that TinyPic is shutting down, so his photo's don't work anymore, just in case he wan't to move them to another site.
Jump to top Robert's_BMW is online now   Reply With Quote
Discussing DIY: E46 M3 detailed ignition coil replacement and spark plug replacement in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
