Old Tue, Dec-19-2017, 05:30:27 PM   #231
Default Re: Best Daily Driver Suspension?
Originally Posted by e46IX View Post
Koni Yellows + TMS H&R springs here. Decent setup for street use, not low enough for my aesthetic taste though. Also the problem with springs is the E46 M3 has this uneven balance from factory where the driver side is higher to "compensate for driver weight" not a fan looks stupid and the only way to remedy this is with coilovers.
... and then end up with the same look, once you corner balance.
function > form
Old Tue, Dec-19-2017, 05:34:57 PM   #232
Cha5en
Reputation: 0 Cha5en is on a distinguished road
function > form
I highly doubt most on here corner balance. I know because I think we've done maybe a handful (only track junkies) in the past few years. Most just throw "coilovers" on and do the alignment.
Jump to top Cha5en is offline   Reply With Quote
Old Tue, Dec-19-2017, 06:19:25 PM   #233
speedblind_az
Reputation: 0 speedblind_az is on a distinguished road
Tires should be part of this discussion. I put the Eibach Pro Street S on my car when it was on RE71s. I was pretty happy with it on the street, but felt that it was harsher then most described in the review. Put a fresh set of PSS on the car and it's exactly what I wanted.
Seems obvious, but it's a reminder that any time we go back and forth over springs, shocks, etc., we should also be disclosing the type of tire we're running. Makes a big difference, and I generally forget to consider it.
FWIW, the Eibachs with stock top mounts (swapped) and 265/18 PSS is a great street setup for my tastes. I just bought another M3 with springs/shocks and the suspension feels far less locked down over bumps at freeway speeds.
Jump to top speedblind_az is offline   Reply With Quote
Old Tue, Dec-19-2017, 06:22:25 PM   #234
I don't understand
Old Tue, Dec-19-2017, 06:50:23 PM   #235
GO4BROKE
Reputation: 0 GO4BROKE is on a distinguished road
Originally Posted by oleg232000 View Post
Thats with the struts and shocks? If its all brand new, i think you did alright
Yes everything except for front strut mounts..all those bump stops and rubber parts add up quickly. Thanks for suggesting that list, I even got front and rear reinforcement plates.
Sent from my SM-G930V using Tapatalk
Jump to top GO4BROKE is offline   Reply With Quote
Old Thu, Dec-21-2017, 01:03:58 AM   #236
SunD3v1L
hi
SunD3v1L's Avatar
Reputation: 0 SunD3v1L is on a distinguished road
Italy
Originally Posted by SunD3v1L View Post
I'll edit this list as we go:
*As mentioned RTABs & FCABs recently replaced, OEM, everything else is old; Eibach Pro-Kit Springs*
- (1) Koni Yellow Left Strut - # 8741-1438LSPORT
- (1) Koni Yellow Right Strut - # 8741-1438RSPORT
- (2) Koni Yellow Rear Shock - # 8240-1203SPORT
- (2) OE rear shock mount - # 33526779670
* - (2) rear shock mount reinforcement plates - # 51718413359
- (2) front bump stop - # 31332229778
- (2) rear bump stop - # 33532229777
edit:
- (2) front lower spring pad - # 31331096664
- (2) front upper spring pad - # 31331091233
- (2) rear lower spring pad - # 33531094518
- (2) rear upper spring pad - # 33531136385
- (2) upper strut beading - # 31331090612 (added 12/20/2017)
optional:
- (1) right front upper strut mount - # 31332229166
- (1) left front upper strut mount - # 31332229165
- (2) front strut rubber boot - # 31331093344 (added 12/20/2017)
- (2) rear strut 'protection tube' - # 33521136283 (added 12/20/2017)
edited some things just now
Can someone with KONI Yellows comment if they came with new rubber boots or not? Every set of pics I've seen indicates no.... worth replacing if they are original?
Added part numbers above just in case...
Jump to top SunD3v1L is offline   Reply With Quote
Old Thu, Dec-21-2017, 01:10:21 AM   #237
M3GA
Reputation: 0 M3GA is on a distinguished road
They do not, I didn't bother replacing mine or the bump stops. Both were in decent condition.
Sent from my SM-G920V using Tapatalk
Jump to top M3GA is offline   Reply With Quote
Old Thu, Dec-21-2017, 01:14:22 AM   #238
SunD3v1L
hi
SunD3v1L's Avatar
Italy
Thanks for the quick reply! How many miles are on your car (if they are original)?
boots and bump stops all around are $150-$200....
Old Thu, Dec-21-2017, 01:22:51 AM   #239
M3GA
120k approx, original. I replaced almost everything else, struts/shocks, bushings, rtabs, fcabs, end links, rsm, low mileage springs, etc
In hindsight, one "mistake" I made was not replacing the rubber shims (upper and lower pads). Thought I could get away with it, but they creak a bit. Just recently picked up the shims and will do next spring. Along with new tie rods.
Old Thu, Dec-21-2017, 01:48:04 AM   #240
SunD3v1L
hi
SunD3v1L's Avatar
Italy
Thanks for the input - Iím planning on ordering the spring pads / rubber shims (thatís what you mean, right?)
I think Iím going to knock out sway bar end links and tie rods down the road, along with a new sway bar kit - should be a nice secondary wave of refreshing while upgrading.
Discussing Best Daily Driver Suspension? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
