Old Thu, Apr-03-2014, 10:47:50 PM   #31
deepinya
ZCP IB CINN
deepinya's Avatar
Reputation: 0 deepinya is on a distinguished road
Default Re: Comprehensive Intravee Thread
Originally Posted by M3-3M View Post
There is a mod that Baris and a few others do that bypasses the internal amps in the BM53. That signal is not strong enough for some amps and allows noise/hiss into the system. Ths signal coming out of the BM53 wires that are going to the HK amp are amplified and need to be adjusted down. If I can find the voltage I will repost. I am using the LC2i in my set up. I also have factory nav and aftermarket amps and components& sub.
So your head unit is completely stock?
I called Audio Control just to ask their opinion and the gentleman said the LCXX series is for after amp installs and would not recommend it for PRE HK amp installs. For that he said use the Matrix Plus or Overdrive Plus.
If you can check the pre-amp voltage that would be great.
Richard is all out of breakout boxes so it doesnt seem like Ill be able to use the PXA after all. I wish I asked about the breakout box before I purchased the PXA unit! lol
Interesting concept, would bypass the need for any sort of loc or line driver.
"Take the line-outputs from the BM53 or CD53. These are amplified as well, but you could never use them as speaker-level outputs, though they are 'full-range'"
If they arent speaker level, they must be closer to line level? I wonder if he knows the actual voltage....I assume would fluctuate with the volume knob?
Jump to top deepinya is offline   Reply With Quote
Old Thu, Apr-03-2014, 11:31:35 PM   #32
I originally had an overdrive using the pre amp outs. It didn't work properly, I forget why. I think there was still a hiss.
Old Thu, Apr-03-2014, 11:53:23 PM   #33
M3-3M
M3-3M's Avatar
Reputation: 0 M3-3M is on a distinguished road
Yes my BM53 is completely stock.
There are a couple guys on here who made their own break out boxes. If I can find their info I will PM it to you. Maybe they would be willing to make a breakout box for a small fee.
Also, If you decide not to use the PXA you probably won't need a LOC. Most later model JL Audio amps will take a balanced differential input which is what you have pre HK amp(I have read that the voltage is around 10-14 volts coming out of the BM53). Many members have done this with good results. Believe me, that is what I would do. But I do like having the PXA and I have had good results with the Imprint Auto tunes. There is a thread on diymobileaudio.com that tells you the best methods for mic placement to give you a proper tune.
2005 ZCP Nav 47k miles - Frank Smith Custom Tune / SGT Headers / Euro Cats / RE El Diablo / Koni Yellows / Eibachs / AKG RSMs / AKG RTABs / 3M Clear Bra / BMW Perf SSK / Intravee II / Alpine KCA-420i / Alpine PXA-H700 / Rocketfish Bluetooth via Optic / Phoenix Gold SD1300.5 / Boston Acoustics Pro 6.4 / Stealthboxes w/ Image Dynamics ID8s / 13th Gen ULF / Homelink Module / Smoked Corners / Black Grills / Black Gills / 35% Tint
Jump to top M3-3M is offline   Reply With Quote
Old Fri, Apr-04-2014, 12:37:35 AM   #34
deepinya
ZCP IB CINN
deepinya's Avatar
damn, sure wish I had the proper knowledge to check it out and report back. I have a harbor freight voltage meter (unused lol) and would happily check if you point out which lines to tap into.
Yeah I wouldnt mind paying a small fee for the box. Richard is actively looking for someone to no avail.
The JL HD amp I have has these specs Input Voltage Range @ RCA Inputs Switchable from 200 mV - 2 V RMS to 800 mV - 8 V RMS
If thats the case, then it cant be 10-14 volts PRE HK amp as many people use JL amps straight with an RCA cable spliced into the wiring.
Old Mon, Apr-21-2014, 07:54:24 PM   #35
deepinya
ZCP IB CINN
deepinya's Avatar
Is it possible to add a rearview camera that displays on the nav screen? From what Ive read you need a tv tuner but not sure if the Intravee supports it.
Old Mon, Apr-21-2014, 08:52:08 PM   #36
yes you can, but it's completely unrelated to the intravee. Just get the factory reverse camera kit. It automagically kicks in when you put the car in reverse and out when you stop.
Old Mon, Apr-21-2014, 09:09:34 PM   #37
deepinya
ZCP IB CINN
deepinya's Avatar
Do our cars support it? I thought the euro versions had some sort of tv module that integrates with the camera.
Old Mon, Apr-21-2014, 09:20:23 PM   #38
The TV module is part of the kit. Neither euro or US cars came with it as standard.
Old Tue, Apr-22-2014, 07:47:34 AM   #39
ccfj1
ccfj1's Avatar
Reputation: 0 ccfj1 is on a distinguished road
United Kingdom
The TT was an extra option (when ordered), but if ordered with nav there was a discount, so **most** cars in the UK that have oem nav also have the TV (as standard).
there is a small add on loom for cars that have nav only, and it allows the connection of the TV module.
Adding a Rev camera to a car with TV, is easy, its 3 wires (on the tv module), 2 wires to power the camera and the camera.
53, M3, Silver Grey. Reto-fits: Modded Mk4 DVD, OEM Bluetooth, VR Control, Rainbow/Alpine Speakers, Alpine Amp, Alpine DSP, Kewood Sub, CCFL, Intravee II, NightMode, Audio Alerts, Rear Blind.
Jump to top ccfj1 is offline   Reply With Quote
Old Tue, Apr-22-2014, 11:52:09 PM   #40
deepinya
ZCP IB CINN
deepinya's Avatar
Unfortunately I dont have the TV. I tried searching for OEM parts but most are used from Ebay and Im not sure how complete it is or if its the correct item.
http://www.ebay.com/itm/181308331603...84.m1423.l2649
There was also a Navik unit on Ebay which isnt OEM
http://www.ebay.com/itm/261244445337...84.m1423.l2649
If you could help me with correct part numbers it may be easier to find.
Is this the loom?
http://www.toysinyourcar.com/acatalog/bmw_av_cam.html
Discussing Comprehensive Intravee Thread in the Audio/In Car Entertainment (I.C.E.) Forum - Place to discuss sights and sounds. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
