Old Sun, Nov-11-2018, 12:28:32 AM   #21
01M3Fan
01M3Fan's Avatar
Reputation: 0 01M3Fan is on a distinguished road
Default Diff from Coupe and Vert the same?--- 4.10 whine?
Whine on decel, no whine under load at any speed. R.E.M. finish, have run BMW & Redline lube and no real difference. Stock diff bushings & aluminum subframe mounts.
My build journal and mod list:
http://www.m3forum.net/m3forum/showthread.php?t=542798
Jump to top 01M3Fan is offline   Reply With Quote
Old Mon, Nov-12-2018, 05:30:47 PM   #22
SlickmisterN
Surrounded By Grapes
SlickmisterN's Avatar
Reputation: 0 SlickmisterN is on a distinguished road
Greece
Default Re: Diff from Coupe and Vert the same?--- 4.10 whine?
I have a coupe that was originally an SMG but converted by PerformanceTechnic.
I am curious as well if there is a difference in driveline geometry that at some point will make installing my new differential (3.91) difficult or impossible?
Jump to top SlickmisterN is offline   Reply With Quote
Old Mon, Nov-12-2018, 05:35:21 PM   #23
SlickmisterN
Greece
Anyone know if SMG and 6mt diff are swappable and what might be needed?
Old Mon, Nov-12-2018, 08:16:27 PM   #24
fattycharged
can't even
fattycharged's Avatar
Reputation: 0 fattycharged has disabled reputation
Zimbabwe
you're good, no issue
Topo Chico
Jump to top fattycharged is offline   Reply With Quote
Discussing Diff from Coupe and Vert the same?--- 4.10 whine? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
