Old Thu, Nov-08-2018, 03:10:31 PM   #1
bmwstephen
Reputation: 0 bmwstephen is on a distinguished road
Default Rear seat upper rubber trim help
Hey guys- i am sure most of you who have messed with your rear seats have seen the upper rear rubber trim deteriorate over time.
Since the part is NLA, the only way to restore it seems to be the plastidip route.
My question to you OGs is should I remove the existing coating first or just fill in the areas with the coating that flaked off? The exist coating could be easily scratched off with a finger nail; exposing a smooth plastic surface but not sure if that was by design in the first place which might explain why the original stuff didnt adhere very well
Jump to top bmwstephen is online now   Reply With Quote
Old Thu, Nov-08-2018, 03:23:06 PM   #2
NolliM3
NolliM3's Avatar
Default Re: Rear seat upper rubber trim help
It appears you answered your question with your explanation.
Old Thu, Nov-08-2018, 03:45:13 PM   #3
huxcrunner
Reputation: 0 huxcrunner is on a distinguished road
You have to remove any of the loose stuff before you put new coating on. I would probably give the whole thing a good sanding and then clean with soapy water or rubbing alcohol before trying to restore it otherwise the same thing is going to happen with it peeling off.
Jump to top huxcrunner is offline   Reply With Quote
Old Fri, Nov-09-2018, 06:40:44 AM   #4
bmwstephen
Well that was a pain in the ass. 2 hours with a razor blade and 70% alcohol.
At least is ready for plastidip
Old Fri, Nov-09-2018, 07:12:33 PM   #5
bluptgm3
Keep us posted on progress!!!
Jump to top bluptgm3 is online now   Reply With Quote
Old Sat, Nov-10-2018, 01:47:18 PM   #6
BMWManiac
Turbo 97 M3
BMWManiac's Avatar
Reputation: 0 BMWManiac is on a distinguished road
I bought these new about 10 x years ago....I can't figure out how these mount into the seats? Do they just press in?
1997 Artic Silver M3
CES Stage IV - 651rwhp/615rwtq@ 24 psi
Jump to top BMWManiac is offline   Reply With Quote
Old Sat, Nov-10-2018, 04:41:59 PM   #7
bmwstephen
You slide them on. Use silicon lube though because these can easily snap if you force it in to hard
Old Sun, Nov-11-2018, 01:03:40 AM   #8
bmwstephen
Finished project. 5 coats of plasti dip (30mins apart per coat) gave it the same texture and thickness of oem
Old Sun, Nov-11-2018, 02:16:42 AM   #9
omairtheman1
Reputation: 0 omairtheman1 is on a distinguished road
Looks good!
Jump to top omairtheman1 is online now   Reply With Quote
Old Sun, Nov-11-2018, 03:42:12 AM   #10
pbonsalb
Good to know. This is on my list, though with the rear roll bar I can’t use the seats and they won’t even fold down so maybe I should just delete them. About all they do now is provide sound deadening.
Discussing Rear seat upper rubber trim help in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
