Old Thu, Aug-26-2010, 11:27:35 PM   #61
ergoyo
Reputation: 0 ergoyo is on a distinguished road
Default Have dimming/compass mirror. Interested in this.
Originally Posted by RaceMX-M3 View Post
The mirrors with the compass do have a one way mirror, and yes the V1 concealed display will work and keep auto dimming. It's not quite as simple as just putting the display behind the mirror. The glass has a special coating applied to the back with a cutout for the compass. Also there is a large circuit board behind the mirror that controls multiple functions, including the oem alarm, compass, mirror dimming, side mirror dimming, headlamp functions, etc. You have to completely remove the coating on the mirror and apply a new coating with a cutout for the V1 (and compass), the plastic mirror casing needs to be modified to so the circuit board can be pushed back far enough to make room for the V1 display, and the compass has to be desoldered and moved about a cm forward if you want to still be able to see it. Be careful, I ruined a few mirrors learning how to do this and they're not cheap to replace.
Are you doing any more of these set-ups? I have a auto-dimming mirror with compass etc and a V1 concealed display. I want to not see any etching when the display is off. Please advise. New to forum so cannot send PM yet.
Jump to top ergoyo is offline   Reply With Quote
Old Fri, Aug-27-2010, 01:50:47 AM   #62
RaceMX-M3
Scott@Radar-Mirror.com
RaceMX-M3's Avatar
Reputation: 0 RaceMX-M3 is a jewel in the rough
Yeah I can help you with it. I don't etch the glass, your mirror will look the same as the one in the OP. I had some custom mirrors made and can now do this so you don't lose your auto dimming.
Jump to top RaceMX-M3 is offline   Reply With Quote
Old Mon, Apr-01-2013, 06:33:41 AM   #63
s4play
s4play's Avatar
Reputation: 0 s4play is on a distinguished road
Default Re: V1 Stealth Integration - E90 M3
Did a custom install in my E90 m3 and did NOT want to modify any part of the car that cannot be reversed. My setup works just as good and costs a lot less
check it out here:
http://www.m3post.com/forums/showthread.php?t=816195
04 GPW/Onyx Acura NSX
08 Rio s2000
16 Dakar M3
Gone, but not forgotten: (gt3/m3) http://www.m3forum.net/m3forum/showthread.php?t=203205
Jump to top s4play is offline   Reply With Quote
e90, integration, stealth
Discussing V1 Stealth Integration - E90 M3 in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
