Old Tue, Oct-30-2018, 09:11:47 PM   #1
Jaredomin
Jaredomin's Avatar
Reputation: 0 Jaredomin is on a distinguished road
Default oe vs koyo rad
doing a cooling refresh,
do I gain anything with spending the extra $100?
tia
car will see autox/some track days
Jump to top Jaredomin is offline   Reply With Quote
Old Tue, Oct-30-2018, 09:39:05 PM   #2
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
Default Re: oe vs koyo rad
if you dont plan on doing any heavy tracking, just go OE.
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@_Frank_Stone_
Jump to top OneFastSicilian is offline   Reply With Quote
Old Tue, Oct-30-2018, 09:50:58 PM   #3
Good
@GOOD_M3
Good's Avatar
Take a look at specifications and ask yourself if it's worth the $100.
Is $100 worth the improved radiator cooling efficiency, increased coolant fluid capacity, and reduced coolant temperatures?
EXTERIORJCSL 1X1 DIFFUSER | VÖRSTEINER CSL BUMPER
PREVENTATIVE ▌VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK | SMG PUMP/MOTOR RELOCATED
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | RESONATED X-PIPE SEC 2 | SPORT (GEN 2) SEC 3
BRAKES ▌STOCK CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌STOCK ZCP BBS 19" | 75MM ECS/TMS F&R WHEEL STUD CONVERSION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V2 COILOVERS | GROUND CONTROL CAMBER PLATES | SDW RTABS
ENGINE ▌TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OEM SNORKEL (FLAP DELETE), OIL CATCH CAN
TRANSMISSION ▌'255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Journal: http://www.m3forum.net/m3forum/showthread.php?t=599036
Old Tue, Oct-30-2018, 10:21:00 PM   #4
Jaredomin
Jaredomin's Avatar
I think it would be worth it.
But good intent and real world results are far apart.
Looking to hear some first hand expierence.
And yes i have read all the koyo threads already.
I also know theres alot of pro oe rad aswell.
Radiators for life from fcp aint bad either
Old Tue, Oct-30-2018, 10:29:48 PM   #5
Drewster
Drewster's Avatar
I would go with the cheaper of the two - they're pretty close in performance.
CSF oil cooler seemed to help most with overall temp, personally
Old Wed, Oct-31-2018, 12:29:57 AM   #6
Kwakjoe
Kwakjoe's Avatar
Even if you track, a new OE does just fine. People overheat because they have a 100k+ old radiator most of the time. Put a brand new OE radiator on mine and haven’t overheated on track or street
Jump to top Kwakjoe is online now   Reply With Quote
Old Wed, Oct-31-2018, 12:40:36 AM   #7
erickrayos
all of those plus eliminating the chance of the plastic part cracking? koyo is a reputable radiator company. can't go wrong w/ them
Old Wed, Oct-31-2018, 07:23:44 AM   #8
speeeding
Reputation: 0 speeeding is on a distinguished road
I prefer OEM. The Koyo slowly got heat creep at the track.
Jump to top speeeding is offline   Reply With Quote
Old Wed, Oct-31-2018, 04:35:51 PM   #9
I'd go new stock.
Old Wed, Oct-31-2018, 11:44:48 PM   #10
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
New OE Radiator is my recommendation as well, unless you're going to go all out for a Zionville (but even then, in your application, totally not necessary at all). The 46M radiator doesn't have any issues with the plastic cracking like the non-Ms....and the OE Radiator is plenty fine for cooling in even the most demanding conditions. This car doesn't have problems staying within temp. At least not until you add FI.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2 ...and more to come!
Discussing oe vs koyo rad in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
