Old Thu, Nov-07-2019, 11:53:51 PM   #1
evanr614
Reputation: 0 evanr614 is on a distinguished road
Default Random Engine Knock When Sitting Still
Iím experiencing a random engine knock that can be felt throughout the vehicle. I would not consider it violent at all, itís pretty mild but still a knock. So far there is no correlation as to when it occurs whatsoever but I have no idea where it is coming from. The idle does not fluctuate with the knock. Sometimes it is 1 knock or a series of 2 or 3 ďfluttersĒ back to back. Where is the best place to start to diagnose this? All injectors were sent off to be flow tested and cleaned, fuel filter has been changed recently, changed spark plugs a couple of weeks ago, always use 93 gas, no codes being thrown. The car has not had a valve adjustment for a long time to my knowledge, not sure if that would matter. Anything helps!! Thanks
Jump to top evanr614 is offline   Reply With Quote
Old Thu, Nov-07-2019, 11:55:32 PM   #2
mrgizmo04
mrgizmo04's Avatar
Default Re: Random Engine Knock When Sitting Still
Most likely a loose heat shield, but can you get a misfire counter to see if that is active?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Nov-07-2019, 11:56:51 PM   #3
evanr614
Definitely not a heat shield. It is more of a thud. Can that be done with an OBD tool and an iPhone?
Old Fri, Nov-08-2019, 12:08:19 AM   #4
sapote
Slowly rev the rpm up and see if the knock rate follows, then it is engine components related.
Old Fri, Nov-08-2019, 12:09:54 AM   #5
evanr614
Iíve never seen it correlate with using the throttle. Always when at a stand still. Car runs fantastic otherwise
Old Fri, Nov-08-2019, 12:52:06 AM   #6
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
Heater valve?
Topo Chico
Old Fri, Nov-08-2019, 02:18:31 AM   #7
icecream
Registered Apples
icecream's Avatar
I think knock is the wrong word here. Its probably missing once in a while, how old are your coils?
Old Fri, Nov-08-2019, 02:22:54 AM   #8
evanr614
Originally Posted by fattycharged View Post
Heater valve?
what makes you say that?
they are probably all original. can they miss without throwing codes? i would hate to replace all the coils for no reason
Old Fri, Nov-08-2019, 03:01:43 AM   #9
icecream
Registered Apples
icecream's Avatar
Before mine go out they seem to do what you describe. Its always just one at a time but smarter to replace all. At least you should have a spare in the glove box to save yourself some headache.
Old Fri, Nov-08-2019, 03:54:03 AM   #10
Kurty
Reputation: 0 Kurty is on a distinguished road
I have the same problem occuring from time to time.
Knock is probably the word I would choose to describe it too. It would knock and you can feel the engine just skip a beat pretty much. Goes away with any throttle input.
I've changed pump, filter, fuel regulator, injectors, coils & sparks. Kinda gave up chasing it. Doesn't do it all the time either. I catch it from time to time.
Jump to top Kurty is offline   Reply With Quote
Discussing Random Engine Knock When Sitting Still in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
