Old Tue, Apr-16-2019, 09:32:30 PM   #1
Stimpe46
Reputation: 0 Stimpe46 is on a distinguished road
Default Anyone run IRP camber plates?
Hi guys, I'm wondering if anyone has had any experience with IRP camber plates? Turner/ECS sells them for ~$300 but I have line of sight to a set for sub $200.
https://www.turnermotorsport.com/p-4...for-coilovers/
Seems like it could be a pretty good deal as long as they wont fall apart... As a brand, I know people run their shifter with pretty good results. I cant find info on anything else.
Jump to top Stimpe46 is offline   Reply With Quote
Old Fri, Apr-19-2019, 05:16:41 PM   #2
Stimpe46
Default Re: Anyone run IRP camber plates?
Anyone??
Someone at least make fun of me for trying to save $$ on an already inexpensive set of camber plates....
Old Fri, Apr-19-2019, 05:40:59 PM   #3
Doesn't look like there's any isolation of the heim ball joint? Not even poly or delrin lining?
Look like they'd be pretty harsh. Track only?
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 SS unres 2.5" sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack
Old Fri, Apr-19-2019, 07:41:04 PM   #4
Stimpe46
I had the same thought. These things seems pretty bare-bones.
They will be used for track and some street/canyon driving. Not a daily driver by any means.
Old Wed, Nov-13-2019, 04:44:38 PM   #5
Boost112
Reputation: 0 Boost112 is on a distinguished road
...im looking at buying camber plates...and these are the most affordable compared to the Ground control street plates...and accept an oem style spring...any one have any additional feed back...as i woudl really like to make a decision...please and thank you!!!
Jump to top Boost112 is offline   Reply With Quote
Old Wed, Nov-13-2019, 04:49:45 PM   #6
Drewster
Drewster's Avatar
Just get Ground Control or one of the other popular options depending on your driving style.
Aside from cost, it doesn't look like these have anything useful to offer. A lot of the suspension brands are popular because you can call in, get parts/ advice/ etc. if you need it.
Old Wed, Nov-13-2019, 09:21:04 PM   #7
eacmen
I would go with ground control. Their service is great and parts are readily available.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is online now   Reply With Quote
Discussing Anyone run IRP camber plates? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
