Old Thu, Nov-14-2019, 07:31:46 AM   #41
A White m3
///M POWER
A White m3's Avatar
Reputation: 0 A White m3 is on a distinguished road
Default Re: Post here if you've had a stock S54 crank damper fail
sure hope we can get to the bottom of this and restore some balance to my S54
S54 E36 M3 // E46 M3 6 // FELONY E36 M3
Jump to top A White m3 is offline   Reply With Quote
Old Thu, Nov-14-2019, 08:17:18 AM   #42
HassanEido
HassanEido's Avatar
Lebanon
fwiw my balancer is the original one, still intact after 4 years of 8500 rpm limiter, hitting that almost daily
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Thu, Nov-14-2019, 01:01:29 PM   #43
bimmerfan08
bimmerfan08's Avatar
Originally Posted by Apex_3472 View Post
I have had mine fail recently. 84k miles on it and about 5-10 track days total on it. Stock flywheel and clutch, redline has only recently been raised to 8200.
Signs of failure was simply a rattle that sounded like a loose pulley, only noticed it thanks to a friend who heard it while I was pulling into the paddock. It split in two.
I was there for this failure. Shortly after, the clutch (friction disc split) on Scott's car failed too. Coincidence? Or perhaps caused by the imbalance of the crankshaft when the harmonic balancer was acting up? I suspected the latter. Could have been a minor manufacturing defect that was exacerbated by the increased vibrations when the balancer went kaput.
"The most difficult part of figuring out a car, the engineering, has been accomplished. Repairs and maintenance are simply dissembling parts and reassembling them." - bimmerfan08
Old Thu, Nov-14-2019, 01:01:47 PM   #44
Very few failed stock balancers showing up in this thread, and people with 0-5 posts love to pipe in when it's about a failure.
I don't intend to preemptively replace mine, though I'll probably take a peak at it from time to time when the hood is open to make sure it isn't looking like the one above.
Old Thu, Nov-14-2019, 01:04:44 PM   #45
eacmen
We needed to replace the front main seal. Thought about swapping in an oe balance from fcp at the same time. Took it off looked perfect. Put the original back on.
Original balancer, 94k miles. Mostly track miles during our ownership.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Discussing Post here if you've had a stock S54 crank damper fail in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
