Old Sat, Apr-12-2014, 01:21:25 AM   #21
Taiyo
Reputation: 0 Taiyo is on a distinguished road
Default Re: DIY: E46 M3 Oil Change
You save my life! Thank you for the DIY/ video!!!!!!
Jump to top Taiyo is offline   Reply With Quote
Old Sat, Apr-12-2014, 01:36:44 AM   #22
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
Originally Posted by x Spades x View Post
I always use 6.5 bottles.
This is a great post!! Very helpful and nice addition to the forums!
agreed
Old Fri, Apr-25-2014, 08:10:49 AM   #23
Yan_j
Yan_j's Avatar
Reputation: 0 Yan_j is on a distinguished road
I just changed the oil on my m3 but I drained the oil, changed the filter then refilled.
Poured 5.5 liters into the engine and when the engine was at normal operating temperature I checked the dip stick and it was full.
I'm wondering if it didn't completely drain because I reversed the process.
Sent from my Nexus 5 using Tapatalk
Jump to top Yan_j is offline   Reply With Quote
Old Thu, Aug-21-2014, 05:19:46 PM   #24
WantE46M3
01LSBM3
Reputation: 0 WantE46M3 is on a distinguished road
Hey fellas I followed this verbatim but now instead of saying oil change it says inspection 15520...it used to say oil xxxx miles so I'm just wondering if I need to do something else??
2001 LSB E46 M3
Jump to top WantE46M3 is offline   Reply With Quote
Old Sat, Apr-18-2015, 05:20:37 PM   #25
Edgy
Constantly Learning M3 and M5 Owner
Edgy's Avatar
Reputation: 0 Edgy is on a distinguished road
Nice video, didn't see until now when I searched for instructions on resetting the inspection warning. Just did spring check up today, oil change, underbody inspection, swap tires side to side.
FWIW, I like Liqui-Moly and use 6 liters. Most BMW engines take 7, but not the S54. Sometimes shops make this mistake.
Also prefer Mahle filters to Mann.
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Jump to top Edgy is offline   Reply With Quote
Old Fri, Feb-24-2017, 12:42:01 AM   #26
SLOWER
SLOWER's Avatar
Reputation: 0 SLOWER is on a distinguished road
Great video. Doing my first S54 oil change this weekend.
Jump to top SLOWER is offline   Reply With Quote
Old Thu, Jul-19-2018, 04:14:03 PM   #27
rbmwiv
rbmwiv's Avatar
Reputation: 0 rbmwiv is on a distinguished road
Thumbs up Re: DIY: E46 M3 Oil Change
No you didnít drain the oil in the filter housing. I do mine your way Itís less messy that way, but I leave the plug out of the drain the oil. Then remove the oil filter cap and let it drain with the plug out. After everything is drained I put the plug in sit the car down level then add the oil and filter.
Jump to top rbmwiv is offline   Reply With Quote
Old Tue, Nov-12-2019, 07:34:21 AM   #28
sekhon1115
Reputation: 0 sekhon1115 is on a distinguished road
Do I really need a torque wrench?
Sent from my SM-G955W using Tapatalk
Jump to top sekhon1115 is offline   Reply With Quote
Old Wed, Nov-13-2019, 10:35:27 PM   #29
Torque wrench lol
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 SS unres 2.5" sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack
diy, e46, maintenance, mclub.la, oil change
Discussing DIY: E46 M3 Oil Change in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
