Old Mon, May-14-2018, 04:56:24 PM   #61
mrgizmo04
mrgizmo04's Avatar
Default Re: DIY: Aftermarket header and section 1 install
Originally Posted by Hender107 View Post
Started this project over the weekend, and everything seems pretty straight forward so far, letting the header nuts soak now. Can anyone offer a little more in depth info/process of extending and routing the O2 sensors (I'm using euro headers and cats). I understand you just pull them put to extend but I don't want to just start yanking and break clips or anything. Also, once everything is out, I'm assuming screw the O2 sensors into the headers before putting them back up into place?
Follow the rear o2 sensor wires behind the block and behind the intake box. You will see they are connected to a harness. You can send that harness down into the tunnel above/on the side of the bell housing and have the wires reach that way. No splicing or artificial extension of wires needed.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, May-14-2018, 05:44:38 PM   #62
DvSkD4
Reputation: 0 DvSkD4 is on a distinguished road
Yes, screw the O2 sensors into place on the euro exhaust before mounting
Jump to top DvSkD4 is offline   Reply With Quote
Old Fri, Sep-21-2018, 01:17:17 AM   #63
grandchmason
Reputation: 0 grandchmason is on a distinguished road
United Kingdom
Originally Posted by Smoked M3 View Post
14. Go underneath the car and loosen the bolts holding the forward exhaust section (aka Section 1 or "S" pipe) to the US headers. You will need a 10mm open wrench and a 14mm open wrench.
I'm in the middle of my install. I just stripped the bolt between headers and section 1 using a 10mm wrench. It is not a 10mm, it is an inverted torx. Going out to buy the torx bit now. Hopefully I can get the bolt out. If not I'm screwed.
Sorry to bump old thread..... but can anyone confirm the size needed of the inverted torx needed to undo section from headers please ??
Jump to top grandchmason is offline   Reply With Quote
Old Fri, Sep-21-2018, 02:17:13 AM   #64
mrgizmo04
mrgizmo04's Avatar
Depends on bolts you have there, the heads will be E10 or E12. E10 is about 9.4mm, E12 is about 11.1mm.
'05 M3 6MT coupe
Old Sat, Feb-16-2019, 10:54:25 PM   #65
espritv8
Reputation: 0 espritv8 is on a distinguished road
What is a CRT? And where do you plug your O2 sensor when you got catless?
Jump to top espritv8 is offline   Reply With Quote
Old Wed, Feb-20-2019, 11:48:33 PM   #66
CRT = catted rasp terminator. A CPI product. CPI is done, but bimmerworld took over, not sure if they have CRTs anymore though.
If you don't plan on using post cat O2s (rear O2s), code them out (hex editor or ecuwerx binary tool) and simply unplug the O2s at the harness as you have no need for them. Cap any left over bungs.
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 SS unres 2.5" sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack
Old Wed, Feb-20-2019, 11:51:31 PM   #67
dtmpowerjc
dtmpowerjc
dtmpowerjc's Avatar
Reputation: 0 dtmpowerjc is on a distinguished road
Didnít know CPI was over. Jack at custom performance was such a nice guy.
Jump to top dtmpowerjc is offline   Reply With Quote
diy, header, install, section 1
Discussing DIY: Aftermarket header and section 1 install in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
