Old Wed, Feb-10-2010, 05:12:30 AM   #1
jyi
jyi's Avatar
Reputation: 0 jyi is on a distinguished road
Default Squeaking from the belt/pulley area during cold start
So I've recently noticed that the car squeaks during cold start.
The noise is not a shrill (like the noise you get from a loose belt) and it not that loud. With a good crosswind you can't even hear it standing next to it. Definitely can't hear it from inside the cabin.
It seems to be coming from the driverside of the belt system.
I've fixed this before on an e46 328i and it turned out to be the idler pulley.
So I figured it must be the same for my car so I went and bought a stethoscope and tried to pin point the squeak but was unsuccessful.
I couldn't seem to hear the squeak when I placed the tip of the stethoscope on the idler pulley.
Where are some other common places that might start to squeak?
Jump to top jyi is offline   Reply With Quote
Old Wed, Feb-10-2010, 05:21:25 AM   #2
fdub
fdub's Avatar
Reputation: 0 fdub is on a distinguished road
Mine makes the same sound for 2-3 seconds on a cold start. I was told that I needed new belts.
2004 BMW lllM3 Coupe
Silver Grey Metallic, 6sp - all stock
DIY: Dimming 60 LED angel eyes
Jump to top fdub is offline   Reply With Quote
Old Wed, Feb-10-2010, 05:41:58 AM   #3
jyi
jyi's Avatar
Yes, in your case, you do need a new belt.
However, mine lasts for about 5-10 minutes while the car is warming up which leads me to believe it's a worn pulley bearing. I'm just having trouble locating it.
So I was wondering, other than the idler pulley, which other pulleys usually come up as a maintenance item for squeaking.
Old Wed, Feb-10-2010, 01:40:41 PM   #4
alanbmoore
alanbmoore's Avatar
Reputation: 0 alanbmoore is on a distinguished road
My Tundra had an intermittent chirp when cold. Turned out it was the "Goodyear" painted label on the belt! They scuffed that off a bit, and it went away. But, it was a new truck with a new belt at the time...
-Alan
'04 M3 - SMG
'94 E36 track car
'87 Mazda RX7
Hotchkis sways - 2.5deg front camber - 18x9.5 VMR CSL reps - Nitto NT-01 275s - PFC06's - Schroth Quickfit
Jump to top alanbmoore is offline   Reply With Quote
Old Wed, Feb-10-2010, 02:57:44 PM   #5
stolidog
stolidog's Avatar
Reputation: 0 stolidog is on a distinguished road
Mine recently had the same problem as the OP. I replaced both belts and that seemed to do the trick.
2004 E46 M3 Tiag - 6 Speed, Blk Interior, OEM 19's
Current Mods:330d Shifter, Orion V2 4300k, TIAG reflectors
2014 Ducati 899 Panigale - Red
Current Mods:LSL Footpegs, Techspec Snake Skin, Opticoat Pro, DP Lower Radiator Guard
2016 X4 3.5i M-Sport - Dark Graphite Metallic
Jump to top stolidog is offline   Reply With Quote
Old Wed, Feb-10-2010, 03:56:25 PM   #6
jyi
jyi's Avatar
i can't be the belts. i replaced them no more than 10k miles ago.
Old Wed, Feb-10-2010, 04:00:42 PM   #7
MadeInPhilly
Reputation: 0 MadeInPhilly is on a distinguished road
if it's squealing it's prob the tensioner pulley. replace it before it seizes and takes your belts off during driving. that is the worst. getting stranded. it happened recently on my beater sentra. I had to get a new nut and force the damaged pulley back on and the belts to drive it home. all this was done on the side of the road cause i didn't want to pay $120 for towing. don't have AAA.
Jump to top MadeInPhilly is offline   Reply With Quote
Old Sat, Feb-13-2010, 03:23:37 AM   #8
kabluey
sup bros
kabluey's Avatar
Reputation: 0 kabluey is on a distinguished road
does anyone have part #s for the idler and tensioner pulley?
Jump to top kabluey is offline   Reply With Quote
Old Sun, Feb-14-2010, 05:50:25 AM   #9
fdub
fdub's Avatar
+1! I am going to replace them whenever I swap my belts.
Old Sun, Feb-14-2010, 06:04:39 AM   #10
fdub
fdub's Avatar
Found the part numbers:
Belt tensioner pulley: 11281748131
Idler (deflection) pulley: 11287841228
area, belt or pulley, cold, squeaking, start
Discussing Squeaking from the belt/pulley area during cold start in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
