Old Fri, Mar-02-2012, 07:04:41 PM   #41
ENGRTEC
Reputation: 0 ENGRTEC is on a distinguished road
Default Re: DIY Guide: E46 M3 SMG Clutch
7 more post and I"ll make a thread about my tranny job
Jump to top ENGRTEC is offline   Reply With Quote
Old Fri, Nov-16-2012, 09:19:39 PM   #42
paffy
Reputation: 0 paffy is on a distinguished road
Czech_Republic
I'm removing my SMG transmission and I got stuck.
I pried out the bell housing by about 10mm from the engine and can rotate it 5 degrees back and forth. However, it's somehow stuck and won't move any further. Is the input shaft stuck in the pilot bearing or in the clutch disk ??
Any suggestions will be appreciated !
Paul
Jump to top paffy is offline   Reply With Quote
Old Fri, Nov-16-2012, 09:35:28 PM   #43
PeteyyPab
So long M3, its been a trip!
Reputation: 0 PeteyyPab has disabled reputation
Italy
did you remember that 10mm bolt that bolts the engine plate to the trans...
look up behind the headers, screws in to the trans bellhousing
TOTALED: 3/20/2011 - I'll miss you M3, HELLO M5, Looking forward to the journey
In the cool still hours of night, you can still hear my subframe pulling away and my VANOS bolts backing out.
VERT Subframe mount failure confirmed 5/4/2010
Current Fleet:02 M5 Carbon Black - 11 335d M-Sport Alpine White - 89 750iL Salmon Silver - 69 F-100 Ranger Peacock Blue
The ones that got away:02 M3 Vert Jet Black - 04 A4 3.0 Quattro Brilliant Black - 77 Mercedes-Benz 300D Milan Brown Metallic - 02 Range Rover Java Black - 84 Mazda 626 Diesel
Jump to top PeteyyPab is offline   Reply With Quote
Old Fri, Nov-16-2012, 09:47:29 PM   #44
paffy
Czech_Republic
Yeah, that one is out. It popped off the dowels and I can rotate it back and forth a bit, so I doubt it's hanging on some bolt. I'm thinking about remounting the clutch slave cylinder, then let the SMG push the clutch down for me....
Old Sat, Nov-17-2012, 06:42:34 AM   #45
paffy
Czech_Republic
It ended up being the starter dowel pin...
Old Sat, Nov-17-2012, 06:52:54 AM   #46
paffy
Czech_Republic
My SMG shifter link pin is absolutely stuck Fortunately, you can drop the transmission without removing the SMG shifter AND kep the lines connected to do a clutch job !
Old Sat, Dec-08-2012, 08:31:02 PM   #47
Ph4nt0m
Reputation: 0 Ph4nt0m is on a distinguished road
Originally Posted by macming View Post
Good write up! I'm not sure if I'd want to pay a dealership $12,000 to get it done though
Did you have to take it into the dealership to get the SMG re-programmed with a GT1? Is there any special tool required beside a clutch centering tool?
THanks,
Ming
12k? jesus christ!
Jump to top Ph4nt0m is offline   Reply With Quote
Old Mon, Jul-29-2013, 01:34:57 AM   #48
rockdogz
Reputation: 0 rockdogz is on a distinguished road
Thank you for this DIY...
For anyone else who may be struggling to get the actuator rod dowel pin back in, I had to put a small screwdriver in the hole in the center of the actuator rod and rotate it a few degrees counter clockwise (it should only go one direction) in order for the hole to line up. The pin actually goes in rather smoothly after doing this...if you are really having to wedge/smack it back in, then the hole is not lined up so stop.
Tom
Jump to top rockdogz is offline   Reply With Quote
Old Mon, Jan-06-2014, 02:24:11 AM   #49
SouthTexasE46
Reputation: 0 SouthTexasE46 is on a distinguished road
Anyone know where to get the flywheel holder tool? I have been searching on ebay, turner, tischer, real oem and ecs. Ecs has a porsche holder; will this one work?
Jump to top SouthTexasE46 is offline   Reply With Quote
Old Mon, Jan-06-2014, 05:10:40 AM   #50
itsme
itsme's Avatar
Reputation: 0 itsme is on a distinguished road
China
Flywheel holder? Are you talking about the clutch alignment tool?
-Wing
2002.5 Stl Grey M3 SMG II
Jump to top itsme is offline   Reply With Quote
clutch, diy, e46, guide, smg
Discussing DIY Guide: E46 M3 SMG Clutch in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
