Old Sat, Apr-18-2009, 03:15:30 PM   #21
buzzm3
buzzm3's Avatar
Reputation: 0 buzzm3 is on a distinguished road
United Kingdom
i tore my acl and meniscus so cant drive stick so figured i would take the day to work on the car instead, i had ordered the dr colorchip after reading this thread and just finished using it on my SG
in total i had approx 40 small (approx 1/16'') chips, and 5 no larger then 1/8'' , from start to finish it took me approx 45 minutes
its very easy to do, you dab it on, smear it with your thumb or finger and them wipe off 2 minutes later, its takes a few tries to get the hang of how much to apply and how hard to smear, i found that the white stick was easiest to apply the paint and then my finger using very light pressure to smear it worked best, (hardly any pressure, barely touching it) removing it is very easy and again no pressure should be used, literally let the fluid and rag do the work, just rub it very lightly back and forth, if you rub too hard it might remove too much.
i was very happy with the results, its obviously not as good as a re-spray but i really dont notice my chips anymore unless i go looking for them, it didint work too well on a couple of chips that were larger than 1/8'' but they look better than they did. I will use this product again and anyone who has chips should try this.
before
after dabbing and smearing
after wiping off excess and buffing with a microfiber cloth
01 Porsche 996tt
00 Porsche 996 carrera
08 MB ML550
08 Audi S4
Jump to top buzzm3 is offline   Reply With Quote
Old Sat, Apr-18-2009, 03:59:01 PM   #22
domino_z
domino_z's Avatar
Reputation: 0 domino_z is on a distinguished road
guys this is no different than using oem touch up paint, then using a mild thinners or prepsol, hell even a clay bar, to remove the excess paint on the clear coat
huge props to the guy who came up with this money maker
*Bilstein *H&R *WORK *OEM CSL *Random Tech *AFE *Tekarbon *Umnitza *RoyalF1 *Grafxwerks *Raybrig *Borla (coming soon)
Jump to top domino_z is offline   Reply With Quote
Old Sat, Apr-18-2009, 04:34:41 PM   #23
buzzm3
buzzm3's Avatar
United Kingdom
no-ones saying it is but for those people who either cant be bothered to run arround buying touch up paint, brushes, thinners etc or those people who dont have enough experience to know exactly what thinner to use or are worried about damaging the paint then this is a good little kit with fool proof instructions and quick results
i'm sure they make a good profit on the kit....i'm also sure the people who make thinners, brushes, paint etc also make a profit, for me the convenience made the price worthwhile
01 Porsche 996tt
08 MB ML550
08 Audi S4
Old Sat, Apr-18-2009, 07:13:12 PM   #24
e46lsb
e46lsb's Avatar
Reputation: 0 e46lsb is on a distinguished road
I use this product all the time. Its great. On the larger rock chips I use the langta blob remover. Dr. Color Chip seems like it just cant do the bigger chips.
Individual- inside and out.
Jump to top e46lsb is offline   Reply With Quote
Old Sat, Apr-18-2009, 09:26:05 PM   #25
playskool1
NorCal's S54 S65 S85 Rod Bearing spc.
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
best way to fix road rash without having to respraying the front end.
01/01 build date[LSB][Cinn.][6 Spd.]MAXIMUM PSI TURBO 14psi PT6266 [230k total miles][original motor]
[115k supercharged miles][17k E85 miles][9k turbocharged miles][1.9k track miles]
INSTAGRAM: @skweakykleen
Full Beisan VANOS overhaul, TMS Subframe Reinforcement, WPC rod bearings = bulletproof
fully built S54 w/ Precision 6870 coming soon!
Jump to top playskool1 is offline   Reply With Quote
Old Sun, Apr-19-2009, 03:02:56 AM   #26
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
I am using it right now touching up a Topaz color... so far it works well.. talked to Dr Chip and he said the best method is to put the paint on the outside of the chip and then roll the paint into the chip with your thumb. I am going to be doing some major road rash chips and will take photos. The chips I have fixed look good.. and the paint matches better than OEM IMO
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. Sold
1970 911T Tangerine
1972 911T Albert Blue
1970 911E Ossi Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Sun, Apr-19-2009, 01:22:41 PM   #27
PSUEng
I use the factory touch up kit but use a fine tipped detailing brush that is safe to use with enamel paint. I picked up a 4 pack from Hobby Lobby for $4. Works good enough for me.
Old Sun, Apr-19-2009, 02:34:52 PM   #28
bmw loe
Reputation: 0 bmw loe will become famous soon enough
I had multiple road rashes and just maybe a few chips on my hood and bumper.
So what I did was taped up the outer edge of the hood grill, headlight/corner lights, fog light, amber bumpers, and the outer edge of my bumper grill. I poured pain supplied onto a white t-shirt and just wiped it on the surface of the car. Worked like a charm with Dr colorchips big size bottle.
I also did the side rear view mirros, the fronts of each four fender, the lower portion of the side of the car below the body molding, and the lower portion of the rear bumper the same way.
Best trick for bigger chips is to allow enough dry time (I would leave most small and road rash stuff on there for a good 15mins). It will require some scrubbing to remove with the supplied solution though. It also isn't recommended to wax the vehicle for a couple weeks. After all, it IS real paint that's being used and it needs time to cure.
-E90 LCI M3 Interlagos Blue / Novillo Silver MS pullies, K&N filter, primary cat delete, Evolve R stage 2 tune, Evolve Servotronic mapping
-e92 335i 6MT sold
-e46 M3 6MT, sold
-e46 M3 SMG, sold
Jump to top bmw loe is offline   Reply With Quote
Old Thu, Apr-23-2009, 07:04:02 PM   #29
55fanatic
I drive the competition
Reputation: 0 55fanatic is on a distinguished road
Greece
Bump any carbon black results yet?
"Making friends, one state trooper at a time"
mods: Eibach lowering Springs, OEM 19s(summer for now), OEM 18s(for winter + track), 330d shifter lever, goodridge SS brake lines, HP Plus brake pads, Delsa CSL Diffuser, VIS CF hood, Flat black kidneys, DDM 55W xenon retrofit(hi and low beams), MyCarr 60+ LED Angel Eyes, Depo Smoked Corners, Alpine flip out, Alpine BlackBird Navigation, Alpine Blue tooth module, Escort 8500 hardwired, 20% tint, Vanilla Pine tree air freshner
Jump to top 55fanatic is offline   Reply With Quote
Old Thu, Apr-23-2009, 07:16:51 PM   #30
kenM3
kenM3's Avatar
Reputation: 0 kenM3 is on a distinguished road
Puerto Rico
Subscribed!!!!
2001 CB/BK 6-speed /// DINAN Software Stage 1,CCFL Angel Eyes, Carbon Air Duct Covers and CSL Style Splitters, Black Grilles, Kamei Eyelids, Borla Exhaust, SS Resonated Sec. 2, Headers, EvoSport Pulleys, K&N 57-Intake, High Performance Coils, Led Tailights, ZCP 19" Wheels...
Jump to top kenM3 is offline   Reply With Quote
black, carbon, drcolorchip, results
Dr. Colorchip a big disappointment notopM3 E36 M3 (1992-1999) 25 Wed, Sep-28-2011 10:54:42 PM
Dr. Colorchip paint repair notopM3 E36 M3 (1992-1999) 6 Sun, Feb-08-2009 07:21:46 PM
WTT : M3 Carbon Black Euro-Spec CSL Bumper for Carbon black OEM Bumper [TYPE]SS Northeast 10 Thu, Oct-23-2008 01:10:29 AM
WTT : M3 Carbon Black Euro-Spec CSL Bumper for Carbon black OEM Bumper [TYPE]SS Parts for Sale/Wanted 9 Sat, Oct-18-2008 06:38:15 PM
Carbon black dyno Results rat3d m Northeast 23 Thu, Apr-17-2008 10:18:18 PM
Discussing Dr.Colorchip on Carbon Black results in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
