Old Sat, Nov-09-2019, 07:18:01 PM   #71
RyanAllison
RyanAllison's Avatar
Reputation: 0 RyanAllison is on a distinguished road
Default Re: Recaro Sportster CS Discontinued
Dealer was able to lock down 16 allocations procured of the soon to be gone CS. Various options. Hit me up if you're looking for a set.
2006 BMW M3 ZCP Interlagos Blue
6 Speed
Supreme Power 18mm / 15mm spacers
APEX ARC 8 18x9.5 +35
MCS 2WNR (Hyperco 450/800) "Flat Ride"
Hotchkis 30mm Front Sway
Autosolutions 30% SSK
CSF oil cooler & radiator
Nitto NT01
Powerflex Control Arm Bushings
Performance Friction PFC08 Pads
IG: @supremepoweragent
Jump to top RyanAllison is offline   Reply With Quote
Old Sun, Nov-10-2019, 05:24:14 AM   #72
ski3doo
ski3doo's Avatar
Reputation: 0 ski3doo is on a distinguished road
Group buy?
Jump to top ski3doo is offline   Reply With Quote
Old Mon, Nov-11-2019, 06:28:36 AM   #73
gonefishing
Reputation: 0 gonefishing is on a distinguished road
thats a shame. it was always a mod i had in mind. the gt looks a little too busy for my taste
Jump to top gonefishing is offline   Reply With Quote
Old Tue, Nov-12-2019, 08:39:56 AM   #74
C///M
Reputation: 0 C///M is on a distinguished road
PM sent.
Sent from my Pixel 2 XL using Tapatalk
Jump to top C///M is online now   Reply With Quote
Old Wed, Nov-13-2019, 07:31:04 PM   #75
RyanAllison
Originally Posted by ski3doo View Post
Group buy?
I could ask but don't know if there is an incentive given the limited number of seats left.
6 Speed
Nitto NT01
Old Wed, Nov-13-2019, 07:47:25 PM   #76
A friend of mine got a pair of leather/heater CSs from you. Looking forward to installing them in his M5
Old Wed, Nov-13-2019, 08:00:47 PM   #77
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
When I had the SPG XL, I tried running the buckle through the hole:
The problem was that the stiffness of the arm that the receiver sits on meant the buckle was aimed very much inboard, towards me. The pictures makes it look much less bad than it actually was.
It was hugely uncomfortable, made it difficult to buckle/unbuckled, and I'd bet unsafe-- as it would have to straighten before it could become load bearing, and I don't know if the receiver would hold up to that kind of twisting force.
I took the plastic surrounding the buckle hole off. That allowed the buckle to have a more natural angle.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable 500lbs Front 600lbs Rear/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ CSL rep 1 piece lip
Jump to top Sandeep1212 is online now   Reply With Quote
Old Fri, Nov-15-2019, 01:05:51 PM   #78
On the Profi SPG XL (seat pictured), there is no plastic surround to remove.
I assume you mean the pole position? If so, good tip for people running that seat!
Old Fri, Nov-15-2019, 04:05:44 PM   #79
jickel180
Fair Enough
jickel180's Avatar
Reputation: 0 jickel180 is on a distinguished road
Originally Posted by lapoune View Post
This is what I'm doing as well. You just want to keep the extension short enough so that is doesn't change the position of the diagonal belt too much.
How's your OEM receiver positioned to where you can use the extender? I'm back to daily driving my E46 again and want to keep my Recaro SPGs + 3 point belt combo.
Jump to top jickel180 is offline   Reply With Quote
Old Fri, Nov-15-2019, 04:28:38 PM   #80
lapoune
Reputation: 0 lapoune is on a distinguished road
I'm doing it with custom floor plates in my M coupe, so I made the plate in a way to to get the receiver slightly below the seat belt hole. I'm pretty short too so the seat itself is mounted decently high which helped.
Jump to top lapoune is offline   Reply With Quote
Discussing Recaro Sportster CS Discontinued in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
