Old Mon, Jul-23-2018, 03:36:13 PM   #21
Joshe46
Joshe46's Avatar
Default Re: Do Stiff spring rates have correlation to subframe cracks?
Originally Posted by twentyseven View Post
So does the spring float in midair or does the rear height adjuster sit on the perch? More pounds per square inch spread out on a smaller area.
The rear height adjuster sits on the perch. And since it threads through the perch, its only on the raised portion. Sounds like its even worse for the perch!
Jump to top Joshe46 is offline   Reply With Quote
Old Mon, Jul-23-2018, 03:38:20 PM   #22
Drewster
Drewster's Avatar
Indeed it is - most suspension kits will actually come with reinforcement plates for that reason
http://m3forum.net/m3forum/showthread.php?t=530583
Old Mon, Jul-23-2018, 03:45:49 PM   #23
Joshe46
Joshe46's Avatar
So would the RE plate help me at all? Or am I just kind of screwed here? Looks like that idea in the thread you linked never took off.
Old Mon, Jul-23-2018, 05:01:25 PM   #24
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Default Do Stiff spring rates have correlation to subframe cracks?
I highly suggest the RE reinforcement plates.
Before and After.
Underneath
Old Mon, Jul-23-2018, 05:04:08 PM   #25
Joshe46
Joshe46's Avatar
Before and After.
Wait a second, why does my adjuster not sit like yours? My threaded tube doesnt make contact with the perch like that.
Old Mon, Jul-23-2018, 06:50:24 PM   #26
mrgizmo04
mrgizmo04's Avatar
With stiffer rates, you need rear reinforcement plates as well as the front ones (front strut towers can mushroom).
What do yours look like in the back?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, Jul-23-2018, 07:00:48 PM   #27
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Really? Post up some pics.
Old Mon, Jul-23-2018, 07:05:58 PM   #28
Joshe46
Joshe46's Avatar
I have both front and rear reinforcement plates. Just not spring perch. But Once I get home from work Ill grab some pics!
Old Mon, Jul-23-2018, 07:06:31 PM   #29
Joshe46
Joshe46's Avatar
Will do once I get home from work!
Old Mon, Jul-23-2018, 07:10:51 PM   #30
mrgizmo04
mrgizmo04's Avatar
Maybe your springs are of stock length and not adjustable. Either way, when you get home, post some pics so we can see.
'05 M3 6MT coupe
Discussing Do Stiff spring rates have correlation to subframe cracks? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
