Old Thu, Jul-19-2018, 07:10:56 PM   #11
M3_JA
Reputation: 0 M3_JA is on a distinguished road
Default Re: Noise after strut rebuild
Springs not orientated properly on perches/hats? Running out of ideas...
lol yeah me too that's why I'm picking your brain. I thought it might have been springs on the first side but I did the second side a day later and made sure they were exactly as stock and still got the noise. So could swapping left/right mounts create this kind of issue. I thought they looked identical but obviously I was wrong so I'm not sure if I put them on the right side...I will have to check.
Jump to top M3_JA is offline   Reply With Quote
Old Thu, Jul-19-2018, 07:20:15 PM   #12
L/R springs are the same. Could be upside down though. You match the egg shape, which is the bottom of the spring, to the egg shaped bottom seat on Konis and stock struts. Sway bar ear facing rear of car.
Truth be told, it shouldn't matter as the weight of the car will, effectively, weld the MacPherson strut assembly together. Nothing should be moving around with hundreds of pounds on it, but maybe the orientation is causing the spring to "jump" or bind in a funny way, I'm not sure.
Hard to tell over the interwebz.
_
Old Thu, Jul-19-2018, 07:21:15 PM   #13
M3_Pilot
I could help you out if you're local. I've pulled apart my suspension multiple times trying to find a knocking sound when I first got my car I could take it off with my eyes closed.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Thu, Jul-19-2018, 07:31:15 PM   #14
M3_JA
Yeah the springs are on the correct side and not upside down but the strut top mount could be on the wrong side. Does it make a difference if I hear the noise with the car on jack stands so the suspension is unloaded?
Looks like I'm going to have to take it apart and try again.
Old Thu, Jul-19-2018, 07:31:55 PM   #15
M3_JA
Thanks for the offer Pilot that would be awesome but I'm in the Seattle area so not close enough...
Old Thu, Jul-19-2018, 11:03:19 PM   #16
mrgizmo04
mrgizmo04's Avatar
So the bottom of the spring sits on a perch that rotates about an axis with the entire strut. The top of the spring sits on this bearing. It sounds to me that the top is not assembled properly and what you are getting is a rotational force on the spring that gets loaded and lets loose and then gets reloaded again as you keep rotating the steering wheel. Check that it is all seated in the proper grooves when you release the spring compressor. It can line up perfectly when everything is loose but then once the spring compressor is released something goes on crooked and pinches, blocking the spring from rotating with the strut.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Jul-20-2018, 03:15:08 PM   #17
M3_JA
Thanks for the detailed explanation. This sounds like what could be happening. I will disassemble them this weekend and double check everything. Does anyone know of a good picture showing how the top is assembled?
Old Fri, Jul-20-2018, 03:37:45 PM   #18
Yes, the official one
_
Old Sun, Jul-22-2018, 05:47:01 PM   #19
M3_JA
OK so I found the problem is not the springs but has to do with the strut mount sticking a little when turned. When starting to turn it, it requires a little extra pressure that causes the thump or pop sound. So I took it apart and checked every piece to make sure it's installed correctly, cleaned with WD-40 and applied some chain lube to parts of the mount to help with movement but still it makes that noise. Also, when it's not tightened down it doesn't make the noise, but when it's tight it gets worse and on the car even sticker. Has anyone run into this? All parts are new except the springs so I can't figure out what the problem is.
Old Sun, Jul-22-2018, 09:01:35 PM   #20
mrgizmo04
mrgizmo04's Avatar
If you assemble the strut without the spring, does the bearing and top mount make the noise when turning by hand? It should spin freely.
'05 M3 6MT coupe
noise, rebuild, strut, turning
Discussing Noise after strut rebuild in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
