Old Wed, Jul-18-2018, 09:59:31 PM   #1
avusblu_e36
Default Small clunking at slow speeds, wheels off everything seems fine, any guesses?
So I've got a 2006 m3 coupe, all has been well recently, all of a sudden the other day a could hear a clunking coming from the suspension/wheels/ect all around the car at slow speeds.
I was turning from a red light, a small bump in the road caused quite the clunking to come from under the car. You could feel it in your feet in the floorboards. At first I thought it was the black plastic shield underneath, even though that seemed light for the clunk I was feeling. Alas, all including the larger metal shield were fine.
I jacked up each front and rear wheels, spun em, took em off, shook everything. I recently put in new bilstein struts, new springs, new sway bar end links. Everything seemed tight and orderly. My guesses of a misaligned spring or bad end link were not correct.
I'm pretty lost at this point. It's strange how no matter which of the 4 corners I roll over a little bump with, it produces a similar clunk. I even guessed a loose/broken steering rack and took off the metal shield to check.
I did stand on the passenger door sill and put my weight up and down on it to bounce the suspension, and that produced a clunk from the front right wheel.
Thanks for any ideas and thanks for the long read if you made it this far
Jump to top avusblu_e36 is online now   Reply With Quote
Old Wed, Jul-18-2018, 10:02:19 PM   #2
lmtfi
lmtfi's Avatar
Default Re: Small clunking at slow speeds, wheels off everything seems fine, any guesses?
Did you look carefully at your subframe and trunk?
Old Wed, Jul-18-2018, 10:05:38 PM   #3
bigjae1976
Driveshaft.
Or your FCAB is totally destroyed. Very possible if itís aftermarket.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Jul-18-2018, 10:11:18 PM   #4
avusblu_e36
thanks LMTFI that was actually my first horrible thought, and I went and ripped out my trunk carpet and got underneath the car and all looked fine.
FCABs look strong, I don't remember but I don't think they had any play.
Driveshaft is a big possibility, I guess I'm just not sure what to check/look for?
Old Wed, Jul-18-2018, 10:15:53 PM   #5
bigjae1976
Start with the rubber parts. The guibo and center bearing.
Old Wed, Jul-18-2018, 10:16:58 PM   #6
rovert604
rovert604's Avatar
Check the front diff bolt.
It seems driveline related. So something down the middle of your vehicle is most probably making the noise.
--Trevor in 604--
Vancouver, BC, Canada
Old Wed, Jul-18-2018, 10:44:17 PM   #7
lmtfi
lmtfi's Avatar
Does it clunk when you get on and off the throttle?
Old Wed, Jul-18-2018, 11:16:58 PM   #8
avusblu_e36
not so much, but I will go for a drive with all these new references and see
Old Thu, Jul-19-2018, 12:42:00 AM   #9
BTB
BTB's Avatar
when my center support bearing went out the driveshaft would hit the trans tunnel and thump-thump-thump from time to time. Ended up with a new driveshaft/csb, definitely best to do this stuff preventatively. not sure if your issue is the same though
My Journal
Jump to top BTB is online now   Reply With Quote
Old Thu, Jul-19-2018, 01:26:37 AM   #10
Red Rider
Red Rider's Avatar
Reputation: 0 Red Rider is on a distinguished road
Had same problem...check muffler hangars.
Jump to top Red Rider is offline   Reply With Quote
Discussing Small clunking at slow speeds, wheels off everything seems fine, any guesses? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
