Old Wed, Jul-18-2018, 08:19:09 PM   #21
Texaz3
Default Re: Idle jumps up and down after hot restart
If it hunts,it aint running right. Your maf would be on its way out more likely than not. If no vaccum leaks and icv is ok, then its ur maf , no ifs buts or maybes about it
I said intermittent.
There is more to idle hunt issue than just MAF.
Old Thu, Jul-19-2018, 06:20:19 AM   #22
HassanEido
HassanEido's Avatar
Lebanon
Trust me on this, it should NEVER have unstable idle. Ever.
It's just how it works. You must've missed the part where I said, if there are no vacuum leaks, and ICV is ok, then your only cause would be your MAF.
An inaccurate maf doesn't throw codes until it's way way off.
For example, a brand new maf will read around 3.3 grams/second(depending on elevation, temp etc..),and as it ages it can up to 6 g/s without every throwing codes. The car will of course adjust for this margin within limit. A CEL will be thrown when it reaches 6.5 g/s or higher. At this point it is way way off, and outside the tolerance. Mind you, the car would be running like crap compared to car with a good MAF, as the car can only run as good as it's maf is accurate(given stock tune etc..).
I have seen an instance where a car didn't have issues, but ran a bit too lean up top(into the 14s), idled fine, but intermittently hunted for idle. His maf read 5.4 g/s. Swapping a new maf, car wouldn't idle anymore. It had been adapted to the old crappy maf so much that it couldn't hold idle. Reset adaptation and it ran perfectly. Rock solid idle no matter what. That's just one example..If had far too many experiences with this than I care to mention. I'm mafless since a few months ago, but I've logged and studied these for 5 years before.
Anyway, my comments are advice to all of you still running a MAF, if it hunts even if intermittently or rarely, it's not running right, change ur maf , and clear ur adaptations.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Old Thu, Jul-19-2018, 01:53:22 PM   #23
andrewrivera141
Reputation: 0 andrewrivera141 is on a distinguished road
I'll try it out brother. Thanks for the insight.
Sent from my Pixel using Tapatalk
Jump to top andrewrivera141 is offline   Reply With Quote
Old Thu, Jul-19-2018, 02:14:07 PM   #24
Texaz3
How do you clear your adaptations after changing MAF? I have MAF on order, so will swap as soon as it gets here.
Btw, I was not disagreeing with you, just said that most cars at this point will have some sort of issue with MAF, icv, vacuum, etc to hunt a bit intermittently. Doesn't mean its not an issue, just maybe not critical enough until it becomes a nuisance.
Old Thu, Jul-19-2018, 03:44:45 PM   #25
Toxic0n
My car has been doing this for 8 years, since the day I got it! Also intermittent and goes away after 30-60 seconds on a warm start so it hasn't bothered me much.
I've cleaned and then replaced the MAF, no change. In that time period I've also replaced the fuel filter a couple of times, spark plugs, coils, fuel pump, etc.
I don't have any visible tears in the intake or anything,
I'm going to be cleaning the ICV and throttle bodies some time this summer, just haven't gotten around it.
INPA or similar tool.
Ground Control, Mason Engineering, HRE, ACS, Rogue Engineering
Jump to top Toxic0n is offline   Reply With Quote
Old Thu, Jul-19-2018, 03:51:34 PM   #26
JamesSJ1
Reputation: 0 JamesSJ1 is on a distinguished road
After my 60k mile work including Beisan VANOS oil disc and seals, I had intermittent idle hunting and thought it was some combination of my valve adjustment and timing. I typically clean my MAF every 10-15k miles, so didn't think that was related. At about 73k, finally cleaned up a very dirty ICV...idle seemed worse especially on cold starts, and so a couple weeks ago at 75k I did another valve adjustment (heard some clicking in there so figured it was worth opening the cover anyway to make sure nothing else was wrong) and that improved my cold start idle to almost rock steady again.
Then...I noticed hunting idle, read this thread, and it matched the conditions...warm/hot start, hunts for about a minute, then settles down to steady. Had it happen a couple days ago on a warm start and pulled the MAF connector. Immediately the idle jumped and went steady. Showed ~1100rpm, where it normally idles at ~800-850rpm. Looks like at about 70k miles my MAF is heading on out and fits what Texaz3 described, so I'll probably start looking for a new MAF sooner than later.
Jump to top JamesSJ1 is offline   Reply With Quote
Old Sun, Jul-22-2018, 06:16:48 PM   #27
zingbmw
Reputation: 0 zingbmw is on a distinguished road
Ive had a bouncy idle for a while. its usually on cold starts and sometimes while idling at a light after warming up. ive cleaned my icv, maf, and throttle bodies, did besian vanos job and valve job. the idle improved the most after the vanos and valve job, but it still hunts for idle occasionally.
Im at 80k mi, so Ill keep an eye out for a MAF meter and post whether or not it improves when I change it
Jump to top zingbmw is offline   Reply With Quote
Old Sun, Jul-22-2018, 08:20:19 PM   #28
mrgizmo04
mrgizmo04's Avatar
I'm selling a new Bosch maf on the forum. PM if interested.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Discussing Idle jumps up and down after hot restart in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
