Old Thu, Jul-05-2018, 06:01:41 AM   #1
zingbmw
Reputation: 0 zingbmw is on a distinguished road
Default help finding source of oil leak
I saw a bit of oil behind the front wheel, while I was messing with the abs sensors. I attached a pic I took from behind the front wheel and one from under the hood. You can see the two shiny hoses in the middle of the pic. The clean spot on the other pic is a bit I wiped away to make sure it wasn't just dirt. The head gasket is clean on the sides and the back felt fine when I checked it after a valve job months ago.
Any ideas where the oil could be coming from?
UPDATE: I replaced the ps reservoir and hoses. The first pic with the oil on the hoses appears to have been caused by this. I also replaced the oring on the dipstick. That leak more than likely caused the oil in the second pic.
http://www.m3forum.net/m3forum/showthread.php?t=606424
File Type: jpg oil leak looking through front driver wheel well.jpg (307.4 KB, 104 views)
Jump to top zingbmw is offline   Reply With Quote
Old Sun, Jul-22-2018, 06:17:28 PM   #2
zingbmw
Default Re: help finding source of oil leak
No ideas guys?
Old Sun, Jul-22-2018, 08:11:28 PM   #3
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
Looks like power steering reservoir and/or hoses. Check clamps under reservoir.
Jump to top Chapelle is online now   Reply With Quote
Old Sun, Jul-22-2018, 08:56:08 PM   #4
mrgizmo04
mrgizmo04's Avatar
Yeah, not too many places on driver side. Check power steering per Chap, those hoses/clamps seep a lot from the reservoir.
Can you tell the difference by color or smell if its oil or atf?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Jul-22-2018, 08:58:56 PM   #5
mrgizmo04
mrgizmo04's Avatar
Ah, forgot, another key one on driver side is the oil filter housing gasket. Hopefully you can nail down what it is by inspecting the ps hoses.
'05 M3 6MT coupe
Old Sun, Jul-22-2018, 11:19:21 PM   #6
walid.m3
walid.m3's Avatar
Reputation: 0 walid.m3 is on a distinguished road
Exactly what I was thinking. I've had this before.
Jump to top walid.m3 is offline   Reply With Quote
Old Mon, Jul-23-2018, 10:02:33 PM   #7
cruisin_psu
cruisin_psu's Avatar
Reputation: 0 cruisin_psu is on a distinguished road
could you have overfilled your P/S fluid? the cap is vented and can leak fluid even at the right level
'17 M240i
Sold the e90.. must take some pics!
Jump to top cruisin_psu is offline   Reply With Quote
Old Wed, Jul-25-2018, 01:16:57 PM   #8
Pic18
Reputation: 0 Pic18 is on a distinguished road
I recently had a leak in the same area and it turned out to be the gasket/seal at the location where the dipstick goes into the oil pan.
Jump to top Pic18 is offline   Reply With Quote
Old Tue, Jul-31-2018, 12:53:20 AM   #9
zingbmw
did power steering fluid a long time ago and this leak is fairly recent, so i doubt its overflow. will check all the ps hoses though (already replaced the one on the bottom of car that always seems to leak) and will check where the dipstick goes into oil pan.
Old Mon, Apr-01-2019, 05:52:14 PM   #10
zingbmw
finally got around to dealing with leaks. updated original post
Discussing help finding source of oil leak in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
