Old Sat, Mar-17-2018, 04:33:56 AM   #1
bimmerdriver
Default Questions about OE Bi-Xenon Headlights
The angel-eyes died so I will be replacing them with umnitza V4.
The angel eyes were installed by the original owner approximately 15 years ago, so the car probably has the original headlight gaskets. There are not any signs of leakage or condensation. Is it okay to reuse the gaskets or should I order new ones?
There is a very thin layer of haze on the outside of the projectors. Is this normal or unusual? Any advice to remove it?
Old Sat, Mar-17-2018, 04:53:15 AM   #2
Halftim3
Reputation: 0 Halftim3 is on a distinguished road
Default Re: Questions about OE Bi-Xenon Headlights
The gaskets should be fine if you aren't getting any moisture on the inside of your current lenses. The stock projector lenses look hazy which is why they usually get replaced with better lenses.
Jump to top Halftim3 is offline   Reply With Quote
Old Sat, Mar-17-2018, 05:15:39 AM   #3
skillzo1
skillzo1's Avatar
Reputation: 0 skillzo1 is on a distinguished road
Get these lenses..it will make a world of difference.
https://www.theretrofitsource.com/co...ses/zkw-r.html
Current 05 IB//BL 6SPD 714RWHP 590TQ
SOLD 05 AW//IR 6SPD
Skillzo's Build...http://www.m3forum.net/m3forum/showthread.php?t=487768
Jump to top skillzo1 is offline   Reply With Quote
Old Sat, Mar-17-2018, 04:15:02 PM   #4
nuc1
Meh
nuc1's Avatar
Reputation: 0 nuc1 is on a distinguished road
They will. Do they still require modification to fit?
Mike
02 TiAg/Black 6MT
18 Acura MDX White/Black Family Truckster
11 Tundra Super White/Black Actual Truckster
Jump to top nuc1 is offline   Reply With Quote
Old Sat, Mar-17-2018, 05:07:46 PM   #5
skillzo1
skillzo1's Avatar
Mike
Nope… just pop the old lenses out and pop these in.
SOLD 05 AW//IR 6SPD
Old Sat, Mar-17-2018, 08:16:06 PM   #6
bimmerdriver
Thanks for the replies. Do the headlight assemblies have to be completely removed and disassembled to replace the lenses or can it be done with the projectors in the assembly?
Old Sat, Mar-17-2018, 08:33:50 PM   #7
nuc1
Meh
nuc1's Avatar
They need to be removed and disassembled. Have to separate the lens holder from the actual projector.
Mike
02 TiAg/Black 6MT
Old Sat, Mar-17-2018, 09:13:37 PM   #8
skillzo1
skillzo1's Avatar
Yeahp completely removed its not hard at all. The first one will take you about 30 min to an hour… to take apart the headlight. Once you know how… the 2nd will take you 15 min. Its a matter of using the adjustments that move the headlight forward and back to properly remove the guts of the headlight. The non painted oem mirror bowls is the oem lense if you can compare them. The picture showing light output is with my fogs headlights and angel eyes on.
SOLD 05 AW//IR 6SPD
Old Sat, Mar-17-2018, 09:23:38 PM   #9
Halftim3
Is the spacer needed?
Old Sat, Mar-17-2018, 09:26:03 PM   #10
skillzo1
skillzo1's Avatar
I dont remember using any spacer on anything… but when/if you order a set… id ask the retrofit source to be sure.
SOLD 05 AW//IR 6SPD
Discussing Questions about OE Bi-Xenon Headlights in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
