Old Sun, Mar-04-2018, 05:24:28 AM   #1
Volgoat
Reputation: 0 Volgoat is on a distinguished road
Default M3 Differential Mounting Bolts
Hello, all. I am doing a full M3 subframe and diff/axle swap on a 2002 330i. I am missing the bolts for the 3 differential mounts (1 front / 2 rear) and I'm trying to find part numbers, but not having much luck searching. Would appreciate anybody that could direct me to them.
Jump to top Volgoat is offline   Reply With Quote
Old Sun, Mar-04-2018, 05:26:57 AM   #2
mrgizmo04
mrgizmo04's Avatar
Default Re: M3 Differential Mounting Bolts
Realoem is your friend. You need #9,10,11, make sure to get the right quantities.
http://www.realoem.com/bmw/enUS/show...diagId=33_1076
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Mar-04-2018, 05:28:34 AM   #3
Volgoat
That was quick. Thank you very much, was unaware of that resource. That will be very helpful.
Old Sun, Mar-04-2018, 05:33:04 AM   #4
mrgizmo04
mrgizmo04's Avatar
make sure you also get the right torque specs, front one is very tight. http://sawashie.free.fr/M3/TorqueSpe...SPECS%20LR.pdf
'05 M3 6MT coupe
Old Sun, Mar-04-2018, 05:34:10 AM   #5
rovert604
rovert604's Avatar
Be sure to torque them correctly. I canít remember what they are off hand but i remember the single front bolt was 143lbs. If itís even a little lose the force of the engine will make the diff knock against the carrier.
The rear bolts I know are somewhat light in torque...totally different than the one front bolt.
--Trevor in 604--
Vancouver, BC, Canada
Old Sun, Mar-04-2018, 05:38:29 AM   #6
mrgizmo04
mrgizmo04's Avatar
Yeah the front is 148, rears are actually around 55 ft lbs, their joint torque is low but then you have an angle torque to apply.
Definitely need to get the front one snug!!!!
'05 M3 6MT coupe
Discussing M3 Differential Mounting Bolts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
