Old Sun, Jul-22-2018, 01:12:13 PM   #9001
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Default Re: What did you do to/for your ///M today?
Iím on the tail end of my 6 speed swap. I plan to flash the dme with the latest euro tune to finish it up. Auto solutions ssk feels oh so nice already.
Jump to top Blaikenstein is online now   Reply With Quote
Old Sun, Jul-22-2018, 04:11:34 PM   #9002
Last week my clutch started doing this:
Obioban and TheSt|g graciously offered to help me out. Opened up the transmission to see this:
Throwout bearing basically exploded. Frankly I'm amazed I was able to change gears at all. We replaced the clutch and flywheel along with most of the wear items in the way and installed an Autosolutions SSK since there would be no other point where it's this accessible. Also installed the Turner Urethane Shift Carrier bushing while we were at it
Ran into a couple issues along the way, but ultimately got it done. Car drives amazing. Clutch is smoother than I ever remember it being, the shifter is ridiculously precise (and I hear it improves with a few miles on it). I got the newest variant of the Autosolutions kit (he calls it the "Autocross" edition) - he says it basically incorporates the E90 SSK technology into the E46 kit. I picked 25% w/ stock shift lever height (this is what Ronald himself runs in his personal E46 M3). Visually the main difference seems to be that the shift lever sits in a bearing / ball joint rather than the nylon cup.
I cannot thank Obioban and TheSt|G enough for their help. I would not have been able to tackle this on my own, and I would have been in a bit of trouble if left with an unshiftable car.
File Type: jpg 37541973_10156244475044597_1111156585490546688_n.jpg (448.9 KB, 490 views)
Old Sun, Jul-22-2018, 05:09:08 PM   #9003
mrgizmo04
mrgizmo04's Avatar
Dang. Do you know what brand it was? Oe or some off brand?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Jul-22-2018, 06:59:46 PM   #9004
Everything was factory.
Old Sun, Jul-22-2018, 08:52:47 PM   #9005
cloudm3
cloudm3's Avatar
Reputation: 0 cloudm3 is on a distinguished road
Spa treatment
Jump to top cloudm3 is offline   Reply With Quote
Old Mon, Jul-23-2018, 05:58:07 AM   #9006
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
trying to decided between keeping my currently installed GC Street camber plates or swapping them for a set of GC Race camber plates I've been "gifted".
it's essentially a free upgrade to some bomb fully adjustable camber plates but I don't really need them unless I want to even out my caster alignment. I can do the swap myself and all I'll need to do is pay for an alignment.
decisions decisions...
Jump to top Zzyzx85 is offline   Reply With Quote
Old Wed, Jul-25-2018, 05:27:06 AM   #9007
nujav
nujav's Avatar
Reputation: 0 nujav is on a distinguished road
Test fitted the Megan headers to see if I had fitment issues, mine fit perfect. Waiting for 2 studs to come in the mail then I can put the car back together, I have an SGT resonated x-pipe ready to install too. Then I ordered the mishimoto electric fan to make more free space in the engine bay and now I want to order a mishimoto radiator and refresh the whole cooling system.
2005, ZCP, SMG, 75k miles
Jump to top nujav is offline   Reply With Quote
Old Wed, Jul-25-2018, 12:44:07 PM   #9008
Blaikenstein
I officially finished my 6 spd swap last night with the EU3 dme flash following terraphantms thread.
Now that thatís done Iíll be replacing the transmission this weekend to fix a broken second gear.
Old Wed, Jul-25-2018, 07:26:14 PM   #9009
Jaredomin
Jaredomin's Avatar
Reputation: 0 Jaredomin is on a distinguished road
please post a review or video of the upgraded bearing ssk!!
Jump to top Jaredomin is online now   Reply With Quote
Old Wed, Jul-25-2018, 09:30:59 PM   #9010
Jeffy JJ
Jeffy JJ's Avatar
Reputation: 0 Jeffy JJ is on a distinguished road
Bootyfication.
Sent from my S8 using Tapatalk
Jump to top Jeffy JJ is offline   Reply With Quote
Discussing What did you do to/for your ///M today? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
