Old Tue, Jul-17-2018, 05:02:54 AM   #11
nextelbuddy1
nextelbuddy1's Avatar
Reputation: 0 nextelbuddy1 is on a distinguished road
Default Re: Trunk floor flexing a tiny bit at higher rpm shifts.
in the video there is an audible light sound that occurs through out the video. almost sounds like something is loose and banging around... is that the sound from your trunk floor? or is that from your diff/diff carrier floating around?
2003 ZHP 332i | S54 6 speed | M3 Conversion
Jump to top nextelbuddy1 is offline   Reply With Quote
Old Tue, Jul-17-2018, 05:38:03 AM   #12
rovert604
rovert604's Avatar
Default Trunk floor flexing a tiny bit at higher rpm shifts.
I will be doing a quick check soon after a night of this...lol:
Car felt totally solid with Vincebar, front cups, and Vinceskinz epoxied on!
--Trevor in 604--
Vancouver, BC, Canada
Jump to top rovert604 is offline   Reply With Quote
Old Tue, Jul-17-2018, 06:21:50 AM   #13
nujav
nujav's Avatar
Reputation: 0 nujav is on a distinguished road
Originally Posted by AussieE46M3 View Post
Funny that you mention that. That's essentially exactly what I am doing.
I had the laser notched tubes arrive last week and I'll be fabricating the first prototype 6-point brace this weekend. Triangulates all 4 subframe mounts with the rear shock towers.
When finalised it will be available in kit for for $650 Aud (~$480 USD). It's entirely bolt in and can be removed when the entire boot function is needed.
I was intending to expand on this brace by designing a bolt in half cage where the back stays mount onto the horizontal bar just inbound of the rear shock towers.
I'll be posting pics here if you'd be interested in following.
https://www.facebook.com/cmpauto/
This full set up is exactly what I want. I'll be ordering one of these when their ready. You can post the pics here. For now I'll get the lower bars installed first.
Yes its from the differential area. Not exactly sure where the noise is coming from but it is making pop noise on accelerations and deccelerations and sometimes while shifting. I took the video to check if it was the rear upper shock mounts and found out the trunk floor was flexing. Everything looks visually fine underneath, I would have to start tearing the car a part to figure out what it is, but the subframe plates looked visually fine, bolts are all tight but front differential bolt hasn't been checked. Anyone have any ideas what it is? I ordered new rear differential bolts cause I probably don't have the updated ones.
2005, ZCP, SMG, 75k miles
Jump to top nujav is offline   Reply With Quote
Old Tue, Jul-17-2018, 06:26:33 AM   #14
rovert604
rovert604's Avatar
I didnít read the whole thread. But could it be a loose diff bolt on the front. You can get at it without taking anything apart and just lifting the rear right corner nice and high for the leverage you need to get it to high torque number. I canít remember but itís around 154lbs but verify that. After bolting my subframe back in that front diff bolt wasnít tight so it caused the diff to bang with/without throttle and gear changes. I also needed to snug up the rear diff bolts which isnít that much torque.
--Trevor in 604--
Old Thu, Jul-19-2018, 06:55:48 AM   #15
nujav
nujav's Avatar
Originally Posted by rovert604 View Post
I didn’t read the whole thread. But could it be a loose diff bolt on the front. You can get at it without taking anything apart and just lifting the rear right corner nice and high for the leverage you need to get it to high torque number. I can’t remember but it’s around 154lbs but verify that. After bolting my subframe back in that front diff bolt wasn’t tight so it caused the diff to bang with/without throttle and gear changes. I also needed to snug up the rear diff bolts which isn’t that much torque.
Checked the front differential bolt and tightened it down to 148ft lbs but its still making the popping noise. I need help diagnosing the popping, I checked all subframe bolts and differential bolt and all is tight and good. RACP reinforcement plates looks intact, no signs of cracks anywhere, rear left wheel arch looks good, no signs of seperation on the common area. Only thing left I can think of is the trailing arm lower ball joint and upper ball joint, those haven't been replaced, the lower ball joint did have some movement but it was circular movement like a ball movement so I'm not sure if its the issue(no play in the rear wheels). Or maybe my differential is going bad.
Discussing Trunk floor flexing a tiny bit at higher rpm shifts. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
