Old Wed, May-02-2018, 04:07:47 AM   #81
Default Re: Introducing the VinceSkinz (subframe plates)
Originally Posted by Jaredomin View Post
How long does it usually take vince to answer you guys?
Trying to get some skinz. And possibly a vincebar. Want to see if a mason brace could work with the vncebar in unison.
I think over next few weeks/months it will take him a bit longer to respond to you.
Old Wed, May-02-2018, 05:01:27 AM   #82
Toasty
Reputation: 0 Toasty is on a distinguished road
Originally Posted by EricSMG View Post
I have a welder and I'm pretty good at welding and so I doubt the epoxy/rivet method is easier in my case. Welding is easy but drilling a bunch of wholes/rivets and messing with glue sounds like a pita.
Could be wrong, of course.
When I spoke to Vince about this, he was strongly in favor of the epoxy rivet method. While others have mentioned that Vince thinks it's just as strong as welding (something he told me as well), the one factor he mentioned that really stuck with me where his concerns that welds could damage the surrounding metal if not done carefully. Now, if you are a TIG wizard and/or MIG magician or you know one, this will likely not be an issue, but I could definitely see this being a concern for the less experienced DIY'er type (such as myself). For me, welding is a much more daunting prospect than riveting and epoxy. I'm sure I'm not alone.
Again, whether or not this is a problem will differ for everyone, depending on how they plan to weld their plates and who ends up doing the work. But as for myself, I'm planning to have Kaiv do the rivet/epoxy method on my car.
Yeah, seconded, see above. Vince actually recently posted a thread here about this very issue as well. To make a long story short, the man has a lot going on and he's also a solo operation, so communications are not ideal at the moment. IMO, your best bet at the moment to get in touch quickly would likely be a combination of his facebook page + patience, unfortunately.
Jump to top Toasty is offline   Reply With Quote
Old Wed, May-02-2018, 06:03:47 AM   #83
rovert604
rovert604's Avatar
Not sure if this helps demonstrate our epoxy application...
--Trevor in 604--
Vancouver, BC, Canada
Jump to top rovert604 is offline   Reply With Quote
Old Wed, May-02-2018, 08:21:07 AM   #84
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Contact him on FB. He should reply on FB.
Jump to top 0-60Motorsports is offline   Reply With Quote
Discussing Introducing the VinceSkinz (subframe plates) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
